Question about Belkin Computers & Internet
Need help opening my nat on a belkin router - Belkin Computers & Internet
  • 2,260 Answers
Reduce the MTU settings on the router to 1365. disable the firewall on the router. open the ports 53, 80-88, 3074 on the router.
Click here for more info on networking
Posted on Oct 08, 2009
  • Prashant M
    Prashant M Dec 05, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
  • 132 Answers
SOURCE: Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Posted on Nov 17, 2008
SOURCE: Belkin G plus mimo
Hi never ever disable nat on your router as that is the one which gives ip address to computer , x-box etc. You can make your x-box live work by just opening some ports
1. open rsp by typing in 192.168.2.1
2. On the left hand side under firewall you"ll find virtual servers
3. Click on that --- You"ll find some fields then check on enable for 1,2,3(ie three rows)
4.Description - x-box for all three
5.Inbound Port: 88-88 ,connection type : udp ,private port : 88-88 for the first row
6. Inbound port : 3074-3074 , connection type : udp , private port : 3074-3074 for second row
7. Inbound Port : 3074-3074 ,connection type : tcp , private port : 3074-3074
8. As FOR the private ip address it is that of your x-box which you can find on the dash board of your x-box . Same for all three rows .
9. Best of luck And do rate me
Posted on Feb 04, 2009
  • 137 Answers
SOURCE: i have a belkin n150 router. how do i change the
you can configure in your router's setting area.
Posted on Apr 09, 2010
govinda123
  • 2260 Answers
SOURCE: restricted nat for xbox / linksys 160n router need to open
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here
to know more about router and network
Posted on Apr 20, 2010
  • 30 Answers
SOURCE: how to change the nat settings
what about to set the ps3 ip address on the DMZ for the router that will give all the ports open to that address and will play freely
try go to advance settings and firewall or game and applications there is where you will set dmz application .
Good luck
Posted on Jul 28, 2010
How do I change the NAT type from strict to open so i can play xbox 360 I have a Belkin 3D54 router
There are several things you need to configure in order to change your NAT to open. Here's a link to help you out:
http://support.xbox.com/en-us/pages/xbox-live/troubleshoot/connection-issues/nat-type-strict.aspx
It has steps that can help resolve your issue.
Mar 27, 2011 | Belkin Office Equipment & Supplies
Nat needs to be open
What particular NAT needs to be enabled. There is an NAT option for the WAN and the LAN interface. You need to go to the router's page and you should be able to see the NAT option. It should be ENABLED.
Feb 04, 2011 | Belkin (F5D8231-4) Wireless Router...
Where is your NAT configuration to open and close it for this router? I've watched YOUTUBE videos on where to find the NAT section and I don't have one. Help me I just want my PS3 to have a type 2 NAT so...
Belkin uses the term "Port Forwarding" in the "Firewall" section of the configuration web pages instead of the term "NAT".
For each port that you need to forward to the PS3, create a separate entry in the "Virtual Servers" section.
If that's too much work, then determine the private IP address of your PS3 and add that address to the DMZ for your router. The DMZ settings area is also in the "Firewall" section of your router configuration web pages.
For more information, go to the Belkin support web site and select "G" for "1" and "F5D9231-4" for "2" and the select either V2000 or V1000 depending of your router version (see the bottom of the router) and download the user manual.
While you are there, check whether there is a firmware update for the router available.
Dec 30, 2010 | Belkin F5D9231-4 Router
Belking g plus mimo 928995 NAT open help
when you solve the issue you have can I borrow a guru to help upgrade from my 2wire modem to my Linksys wireless Router?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a belkin wireless g router and my nat settings are strict?
I understand your problem..To fix this issue all you have to do is,You should open the x- box port numbers on the belkin router(please call tech support for assistance),
And also i would suggest you to assign static ip on x-box on belkin range(192.168.2....) then you need to enter same number on router under DMZ. It may be quiet difficult for you to do all this.please call toll free number"belkin".
Dec 17, 2008 | Belkin (F5D7230-4) Router (587009)
Hope this helps!
Nov 15, 2008 | Computers & Internet
Computers & Internet Logo
560 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
