Question about Kenmore Dishwashers
Kenmoore Quiet quard 3 Model #665.74363K1 Serial #FS3502091 The unit will not drain properly. When in drain mode, it will drain slowly when diconnected from the disposal and lowerd to floor, and drains even slower at disposal level, or hooked to disposal. Disposal nipple is clear. I removed the hose and flushed it out with high pressure, found no blockages, hose flows freely and did not fix the problem. The motor is turning and seems to pump water fine, all wands are truning with powerfull spray. I disassembled the internals all the way down to the black base plate the motor is mounted to. I found no blockages in any of the components, the drain outlet where the water exits to the drain hose. I know there is a rubber disk in the outlet to the drain hose that acts as a one way valve, but I did push a rod through to the outlet side of that nipple when the hose was off and found no blockages. I found a small piece of a steak bone and a bread tie in the first section of drain mechanism, but nothing that had reached any moving parts. I see no obviose damage and the unit sounds factory perfect, it just will not drain. Any ideas?
5 Suggested Answers
  • 351 Answers
SOURCE: ASKO 1475 Does not not pump out and drain at end of cycle.
If dishwasher drains ok into bucket then fault is with the house plumbing
Posted on Feb 29, 2008
IFIXALL
  • 868 Answers
SOURCE: BABHMJ's dishwasher husband
You need to pull out the D/W so you can get access to the water pump and remove the hoses to see if its clogged.
Posted on May 26, 2008
SOURCE: ge profile dishwasher not draining Model no.
Did you ever figure out how to remove that large mesh bit? I am stuck at the same spot and would love a hint.
Posted on Sep 23, 2010
heatman101
  • 43501 Answers
SOURCE: My Kenmoore 665 15989990 is
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Dec 21, 2010
Totaline thermostat went blank. No 24 volts between R-C
You either have an open 3 or 5 amp fuse at the indoor unit, open transformer at the indoor unit, loose or broken wire connection from the indoor unit to the tstat, or a bad tstat. Could be a low voltage short that damaged the fuse/transformer. Or damage to the wires that caused a short.
Mar 31, 2017 | Heating & Cooling
Owners manual for cpf12xhl-uv-p
In the back of your unit, there may be a black cover that gets screwed off, a drain hose can get attached here, also, if your unit is plugged into any kind of surge protector or extension cord, try direct to wall, you may hear a beep, this is good, then try to power unit on, if it has different modes start slowly on fan mode, then adjust to a/c mode to see if it quits. i hope this helps you. Good luck.
Feb 23, 2015 | Haier 12,000-BTU Commercial Cool Portable...
Managemylife com sears
Bought a new Whirlpool dish washer from Sears. Can I take the drain hose off the hanger and install to my sewer system. Does drain hose need to be elevated to operate properly?
Jan 01, 2014 | Computers & Internet
Kenmoore a/c split system R410A freezing up
Hi ,I am an Hvac tech as well,check to see if ductwork sizing is capable of handling 1200cfm.sounds like system is low on airflow and u are slightly overcharging.need to be at least 115 back and 290 I head at 80 degree ambient
Jun 13, 2012 | Kenmore Heating & Cooling
My Kenmore Elite Quiet Pac 4 allows water to slowly come in after a cycle has finished and everything says it is off. What is the problem?
There is a valve inside your washer that needs to be replaced. Call sears and have them replace it. You'll need to give them the model and serial #'s.
Jan 11, 2012 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
i thought I responded to this.
make sure the air gap in the kitchen plumbing (if installed is clear). Also check the kitchen drain is not blocked. If using garbage disposer in sink, then make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
BTU's on Emerson Quiet Kool A/C
AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
Rattling compressor on Kenmoore bottom freezer refrigerator
IF IS NOT 5 YEARS OLD YET CALL A TECH ASAP THIS MODELS HAVE A COMPRESSOR THAT ARE FAMOUS FOR LOCKING UP AND THE ONLY FIX IS TO REPLACE IT BUT FIRST DISCONNECT AND REMOVE BACK COVER AND RIGHT BY THE COMPRESSOR THERE IS A SMALL BOX ATTACHED TO IT CALL A OVERLOAD REMOVE IT AND SHAKE IT IS IF RATTLES THEN JUST REPLACE THAT PART IF IT DOESNT RATTLE CALL A TECH
Nov 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE SPLIT UNIT
I would check the unit to ensure that it is draining towards the pan assy. should be 1/4" per foot.
May 29, 2008 | GE Quiet-Aire Ductless Heat Pump Split...
Maytag 300 Quiet Series Dishwasher
Unit will not turn on..had this unit for 6 months..worked fine..all of a sudden wont turn on now..checked power and connections..all were good..im stumped..just wont turn on.
Feb 15, 2008 | Dishwashers
Dishwashers Logo
122 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
