Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
My oven is white with a black door. The elements
My oven is white with a black door. The elements don't burn and I can't figue out how to get the elements out of the range to see if this ia actually my problem.. I can't find the model number
  • milten1
    milten1 May 11, 2010
    model number for frigidaire is found in the drawer compartment pull out the drawer and look on the corners near the legs or on the back of the drawer facier
  • Frigidaire Master
  • 8,220 Answers
Here area few movies (for quicktime player)
Posted on Oct 08, 2009
Why has baumatic B501SS oven covered in light gray coating inside when heated, now not working
It sound like the heating element burned out. Check the element and see if there is a burned spot or blister somewhere along the element. If so the element will need replacing.
May 03, 2014 | Baumatic B180 Electric Single Oven
Oven does not heat up
That pop could have been the element. Check all around the element for a bubble or a large pit/hole. If you don't find anything then check for a burned wire in the back (please unplug the range). Does your range have fuses? If so then check the 30A fuses, but if one is blown you'll have to find the short that caused it, usually a burned wire fused to the chassis or a burned out element. There are many things that could have caused this but these are the most common. Cheers
Nov 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
How do I replace my oven element
Hello.
Theoven is a particularly sturdy piece of kitchen equipment. It can handle dailyuse and still perform as needed. But of course, as with everything over time,the oven can eventually have some things go wrong with it. The first signs maybe subtle, like your cake not being cooked through, or you may notice the oventaking much longer than usual to come to temperature. When looking inside theoven as it is heating, you may notice tiny sparks along the bake element. Anyof these symptoms may mean it's time to replace the bake element.Instructionsand tools below Screwdriver, Newbake element, Electrical tape, Fiberglass tape, Flashlight1 The first step when it comes to working on yourelectric oven is to turn the breaker off at your home's service panel, orbreaker box. This is extremely important, because most electric ovens require220-volt electricity to operate, and that voltage won't only hit you hard, itcan kill you. Place a sign on your breaker panel stating that you are workingon the electrical. As an added precaution, unplug the oven from the walloutlet. Remove the drawer below the oven chamber to see if the plug isaccessible from there. Otherwise, you may have to pull out the oven a bit tounplug it.2 Be sure that the oven has not been used in a whileand that the elements are completely cool. Remove all of the racks from insidethe oven. If it makes it more comfortable, you can even remove the oven door byopening it and sliding it off of the "arms" that hold it in place.3 Locate the bake element. It resembles a metal tubethat's been bent into a square shape and it is located on the bottom of theoven's interior. It can be quite dark inside the oven, so grab your flashlightand shine it to the rear of the oven's interior to locate where the bakeelement is connected to the oven wall.4 There will be two screws holding the bake element inplace. Remove the two screws and place them somewhere where you will not losethem. Now, pull the bake element out of the oven wall. There will be wiresattached to each "leg" of the bake element. Note: There is usuallynot much wire to work with, so do not pull too hard. Once you have about 4 or 5inches of wire exposed, place a piece of black electrical tape over the wire atthe point where it enters the oven. This will help keep the wire from fallingback inside the hole.5 At the point where the wires are connected to thebake element, you should see a screw. Remove the screws and separate the wiresfrom the bake element. Keep the old element for reference when shopping for anew element that matches the old one exactly.6 Install the new element by connecting one wire toeach leg of the element with the screws, just as they were with the oldelement. Wrap a layer of white fiberglass tape around the terminals. Push thewires back through the holes in the rear of the oven until the bake element isback in position. Use the screws to secure the new element to the oven wall, asbefore.7 Replace the oven door if you removed itearlier. Plug in the oven, then turn the breaker back on. Turn on the oven andtest the new element. You may notice some smoke coming off of the element as itheats up for the first time. This is ok, as these are just oils burning off ofit. The smoke will stop in a few seconds.Thanks.
Sep 28, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My newly installed Frigidaire wall oven, model FGEW3065KF fails to heat up except for the convection element. Broiler element makes no heat at all and bake element is uncertain because it is hidden. Before...
I think I can help you but i am a bit confused with the panel box and the junction box. If you want to reply explain the circuit in a bit more detail from the switchboard where the fuse is to the back of the oven. It would also be a good idea to have a voltmeter or test lamps handy. Does the double pole breaker do the Active and Neutral or is it 2 phases going through the breaker. Did the wiring used to be for a full range and now there is only the new oven in its place.
Feb 11, 2011 | Ovens
My oven takes too long to heat up. I think the bottom element is not working properly. Is there some way I can test it?
If the bottom element is accesable take a piece of thermal printing paper and lay it on the element, then switch on. If the element is working the paper will turn black where it is in contact with the element, if you are daring, test it as you would your cloths iron, with a wetted finger, if it sizzles, the element is hot. You are not touching the electrical wiring, only the cover, but be fast with the touch test, you do not want to burn yourself. If the element is not directly accesable, try the thhermal paper test over the cover of the element, leaving the door open, it should turn black where the slots are in the cover, and then blacken all over. (Check to see if the oven switch does not have a position where the bottom element is isolated).
Jan 10, 2011 | Whirlpool RBS275PD Electric Single Oven
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
Apr 17, 2010 | Ovens
The Bottom oven element has burned out. Is is
It's replaceable,if it's an exposed element meaning you can look in the oven and see the element you can do it yourself unplug the range take out the two screws securing it pull it slowly toward you,unplug the two connectors and put in the new one,if it's a hidden bake meaning you can't see the element you would be better off having it done.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
Jul 09, 2009 | Thermador SC302T Electric Double Oven
Bottom oven element sparked then quit working
The element sometimes will continue to arc inside after it burns out. It's 220 volts jumping across the break.
Mar 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
66 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
