Question about Sony 2GB Memory Stick PRO Duo Memory Card
My camera uses a Sony memory stick duo and my laptop reads that fine. i bought a Sony 2Gb Memory stick PRO Duo and put it in a Memory stick Dou adaptor and it works fine in the camera but my laptop wont recognise it. i am running vista home premium can anyone be of assistance thanks
  • 1 more comment
  • isicob Oct 08, 2009
    so what can i do,i have 400 photos there and the camera can read it fine?
  • isicob Oct 09, 2009
    hi there
    i tried to do as you suggested but i came to a dead end.
    my computer is running on vista premium.
    i went to control panel, then device manager ,right click on computer icon then click on property,
    then i got, general computer all i can do is say okay or cancel.
    so i reaches a dead end.
    i am no expert on computer but if i uninstall all usb drivers how will anything connect to the computer?
    i am sure there is a simple answer and you will set me straight
    thanks
    Trevor
  • isicob Oct 10, 2009
    hi
    my laptop has a built in card reader.
    when i insert it it recognizes that this port is open, but it prompts me to insert card, but the card is already in
  • Sony Master
  • 6,487 Answers
You can try to connect it on a different memory card reader and then format it first then after that everything should be working fine....
Posted on Oct 10, 2009
  • 4,281 Answers
For that go to device manager.
Right click on my computer icon then click on property then hardware then click on device manager.
then select USB driver 1 by 1 and uninstall all 1 by 1.
Then restart computer then check.
Let me know if you need more assistance.
Thanks.
Posted on Oct 08, 2009
  • You can use card reader for your memory stick.
    Put that memory ctick in card reader.
    Connect your card reader to computer with usb cable.
    Then you can see your memory stick in my computer as "Removable disk."
    Thanks.
    Brigadier General:
  • 3,614 Answers
the device driver was not installed and not supported by your OS, even you try to install the correct driver it will not reads as a valid driver, it was OS dependent as I know it will work on bit64
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
Bought used camera Sony Cyber Shot Model DSC-P32. What Memory Stick do I need?
You can use Memory Stick standard, pro or pro duo up to 2GB with the Camera.
    A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo™ or MagicGate Memory Stick Duo media.
I have provided the Memory Stick compatibility chart for your reference.
http://esupport.sony.com/US/perl/support-info.pl?&info_id=12&mdl=DSCP32
Feb 09, 2011 | Sony Cyber-Shot DSC-P72 Digital Camera
My laptop cannot read memory stick pro duo 2gb
same problem here The driver is recognized but not opened
Mar 14, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I have a Memory Stick Pro Duo 8GB will not open on my computer or camera..was working then quit. Advice please
Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
Jan 02, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
2gb stick is the pits for me...
check your pc because your pc occur a risk of virus change your antivirus then format your sony pro duo 2gb.
ok
Jul 30, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Pictures stored on card, and unable to retreive them on camera
Have you tried accessing the pictures via a card reader connected to your PC. It is possible the card is damaged and you will not be able to recover your pics. But it is worth a try. If you do not have a card reader take the card to a camera shop and see if they can see and manipulate the pics to another card, then reformat the card and reinsert it to see if it then reads anmd writes.
Jul 22, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Memoy stick pro dou and my p900
SE P900 does not support memory stick pro duo. it' s only support MEMORY STICK DUO (w/o PRO). i have the same problem too. my p900 only live with 32MB MS DUO and there are no more MS DUO in my city (even SE's service center)
if you wanna use your MS DUO PRO, then you'll need to upgade to P990i or P1i. that's much better then P900i (newer OS, more ROM, new keypad, plus WiFi) :D
Dec 24, 2008 | Sony Ericsson P900
64mb to 2 G memory stick dou
The 2 GB memory stick should work in your P990 and not cause any noticeable slowdown.
May 01, 2008 | Sony Ericsson P990i Cellular Phone
Sony 2GB Memory Stick PRO Duo Memory Card Logo
59 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Computer Links
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
