Question about Lexmark X2500 All-In-One Printer
I refill black lexmark 28 ink but it says its empty and to change cartige
  • 103 Answers
Try to check again if you have inserted it to correct position and cartrige area.
Posted on Oct 08, 2009
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    My lexmark X5410 will not accept the black and colored refilled ink cartridges from walgreens. It keeps reporting that the right cartridge is missing.
    If you have refilled the cartridges 28 and 29, it's pretty normal that your printer won't print. Those cartridges are not for refill (they can be refilled, but won't work once the printer says they are empty). If you have refilled a 28A and 29A and it doesn't recognize the one of the cartridges, try removing them and clean the electric contacts with a dry cloth. Put them back in. If that doesn't help, I suggest you buy a new cartridge.
    Apr 11, 2010 | Lexmark X4530 InkJet Printer
    I got my ink cartridge refilled but it's still saying its empty, how do i get it to print anyway?
    So as MUKHTAR states, do not refill cartiges when they are TOO EMPTY as most of the new printers have a sensor in the cartige that tells when it is empty. and when that sensor fills that the cartige is empty, it stays that way, no matter how much you refill it.
    on the laser printers, when you refill your toner cartige there also is a chip that is changed (the sensor) because once that sensor feels that the cartige is empty you will not be able to use that cartige anymore.
    Nov 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Can you tell my printer cartiges was finish i refil new cartige and put in the printer but printer does not work only for printing from computer but fax is working photocopy is work and sccaner is also...
    Please follow these tips
    1. turn off your printer for one menu t and then turn it one.
    2. You should charge your ink the option may be in your Pinter software or there should a button in your
    Pinter to charge your ink.Press
    OK to begin charging the ink.
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}you need to disable the ink level monitors afterre-filling the cartridges. go to properties, maintenance, view printer status,option and click enable status monitor once
    Nov 22, 2008 | Lexmark Office Equipment & Supplies
    Refilling lexmark cartridges x2500
    There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
    Aug 10, 2008 | Lexmark X2550 All-In-One Printer
    Lexmark Black cartridge 28
    You cannot refill a 28 that has been through a refill program. Look at the box dose it say refill program cartrage ?? then you can't refill it, it will always say empty.
    You can however refill a 28A.
    May 13, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark X2500 All-In-One Printer Logo
    182 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
