Bought used washer porcelain tub finish is worn off in bottom
Bought used kenmore washer-porcelain tub finish is worn off in bottom didn't think it was going to be a big problem but it is - it's really damaging clothes - especially knits but it's also messing up even towels. bought a product called restore-4 to try-anyone used it? sounds more like a cleaner than a finish restorer. Tub looks like someone washed a load of rocks in the bottom - it's really bad. Thought about using a porcelain paint but i guess you'd have to remove the tub and I have no idea how to do that. any suggestions???
  • Mattie Martin Jan 20, 2010
    Was helpful but machine did cost $125 and can't afford new one right now so can't just toss it - any other suggestions will be helpful and appreciated.
    President:
  • 1,304 Answers
Get rid of the machine
cant imagine a machine that old really cost that much.
pocelain is baked on and is glass so any edges will catch and destroy cloths
Posted on Oct 08, 2009
Oil in the bottom of washer
The oil is leaking out of the agitator gearbox. The water is coming from the seal on the agitator. I think the gears are badly worn..
Nov 19, 2013 | GE Washing Machines
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
WHY IS THERE RUST IN MY WASH MACHINE DRUM
Hi
Thanks for using FixYa. Take out the clothes immediately after the washer stops spinning. Also clean the tub with a rust remover. This issue occurs due to bad drum bearing and it may be grease rather than rust. Although the tub is metal with porcelain coating and it wears around the edge of the holes first, leaving metal without porcelain. On spinning the centrifugal force pushes the clothes against the basket and some water sneaks into the holes. Due to this you may see the rust on clothes. If still the issue persists, then the tub is required to be replaced to resolve the issue. Please do rate the solution and revert for further assistance. Thanks Rylee
Sep 18, 2009 | Kenmore 24032\24036 Top Load Washer
HE3T Kenmore Frontload Washer Random Draining Problems
The water pumped goes right back into the machine. It may be because the washer is siphoning the water from the laundry tub with a slow drain and back. Your solutions are advised but try this also:
  1. Check the pump impeller for obstruction.
  2. Cut the drain hose into the laundry tub in excess of 4 inches.
Aug 21, 2009 | Kenmore Elite 45986 Front Load Washer
My washer is thumping
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 08, 2009 | Kenmore 24032\24036 Top Load Washer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine. ......Model 25842400
You can go on to sears website to Manage My Home and pull up your manuel for free. Just have your model number.
Apr 30, 2007 | Kenmore 25842 Top Load Washer
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
