Question about Whirlpool GSW9800PW Washer
Whirlpool GSW9800PW Won't Start
My machine quit starting (agitator) when we close the lid. The unit is fairly new (1.5 years). You have to salm the lis hard multiple times to finally trip the interlock. Is anyone else having this problem?
    President:
  • 497 Answers
You may just look into replacing that switch. You shouldnt have to slam it, and by doing so could be causing damage. Its a cheap fix.
Posted on Oct 08, 2009
Won,t spin
lid switch under the control panel,depending model some will install from the top,the others require installation f the cabinet being removed
Jul 10, 2011 | Whirlpool GSW9800PW Washer
Whirlpool High Capacity washer, start cycle , it fills with water then no agitation, and no spinning.
next time send the model number,open the lid,look on the right side and there should be a hole in the top,that's the lid switch,it's used so the washer won't run if the lid is open for safety reasons,set it to spin and with a screw driver push down on the plastic piece in the hole,if nothing happens push in and release,do this a few times,if you don't hear a clicking sound when you push up and down the switch is bad or close the lid and open it an inch,close it and open it a few times,no clicking sound the switch is bad.
Jun 12, 2011 | Whirlpool 3.2 cu. ft. Washer
Agitator doesnt start
Sounds like the lid switch is acting up on you.
Jul 26, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer doesn't spin out
Whirlpool and Frigidaire top load washer sometimes have a problem with the lid switch / lid lock mech. Sometimes it's just a matter of screws backed out due to vibration, Whirlpool models from 2004, 5, 6.
May 11, 2009 | Whirlpool GSW9800PW Washer
Agitator on Whirlpool Ultimate Care II won't agitate
you can replacethe gears taht cause the agittion called agitator dogs part number 80040, probly $20.. reomveth efabric softener( swift smack with thepalm of you hand) and then remove the agititor with a 7/16 screw down the center shaft. the agitator will "split to reveal the "dogs" fairly easy repair
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
MY WASHER IS FULL OF WATER BUT WILL NOT START CYCLE. POWER IS ON TO THE WASHER
Need to replace your lid switch.
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Dec 18, 2008 | Whirlpool GSW9800PW Washer
Washer will not agitate
It would help to know what washing machine you have.
I'll assume that it is a top loading, direct drive washer less than 15 years old.
If that is false, please send more info, otherwise.....
When the washer is done filling, is the...
1: Motor running, but agitator is not moving? Probably a motor coupler, if that's ok, the transmission is probable.
2. Washer silent, motor not running? Check the lid switch, some models will not agitate without the lid closed, see if the lid plunger is missing, or if the lid switch actuator is loose/broken, if you can see the lid switch actuator, try depressing it with a pencil or some other slender, non-conductive item, sometimes the switch breaks just enough so that the plunger on the lid cannot reach it. If that checks ok, you will need to start making voltage reading from the timer to the motor. hopefully it will not come to that. : )
Sep 15, 2008 | Whirlpool Washing Machines
Washer won't start spin cycle
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine trouble
it sounds as if your lid switch is out of position. in the past depending on the model i have taped a penny or two to the top of the switch so the plunger makes contact
Jul 21, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool GSW9800PW Washer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
