Question about Epson STYLUS CX5900 Printer
Its saying im out of ink and i just installed new cartridges all 4 and printer is fairly new
  • mackays11 Oct 08, 2009
    Thank you- but I have not got this option just push a button that indicates the cartridge is installed but then it just comes up error 2 install new cardridge and each time its a different colour.
  • 103 Answers
When replacing the cartrige and install it in your printer have you select the option their saying new cartrige installed?
Posted on Oct 08, 2009
The black printer cartridge leaked a fair amount of ink in to the printer. I am getting all lights flashing and the printer won't even turn off when I hit the power button. I did some cleaning and it...
Sorry to hear that.. here are some instructions that should help you out:
Instructions
things you'll need: Microfiber cloth
1. Ink Cartridge Errors
2. Turn the printer on and open the ink cartridge cover. Wait for the cartridge carriage to stop completely before reaching into the printer.
3. Press on the top of each print cartridge, then pull the cartridges free from the carriage. Make sure you are only using HP cartridges labeled as "HP 60" or "HP 60XL."
4. Reinstall the ink cartridges and close the cover. If the ink cartridge error message displays again, remove the ink cartridges as before.
5. Clean the copper metal contacts on the cartridges using a dry microfiber cloth. If you still see the error message after you reinstall the ink cartridges, replace hem with new cartridges.
Print using the device's ink backup mode if you do not have a replacement for one of the cartridges. Remove the cartridge you cannot replace and close the cover and continue printing. The printer will automatically use the backup mode until you install a new cartridge.
Mar 21, 2011 | HP DeskJet F4280 All In One Printer InkJet
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Thanks,
Pat
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
Says Black ink supply expired. Installed new
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 10, 2009 | HP OfficeJet 7140xi All-In-One InkJet...
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
HP C6280 with new ink cartridges shows cartridges empty
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Feb 03, 2009 | HP C6280 All-in-One Printer
DCP-130C COLOR INKJET
When inserting a new cartridge, you may receive a prompt
"The installed ink cartridge differs from the original ink cartridge for the printer. Your printouts may be different from those printed using original ink cartridges. Do you want to continue using the currently installed ink cartridge?"
If you click Yes, printing will continue. If you select No, you will be prompted to change the cartridge. Manufacturer prompts may vary.
Nov 21, 2008 | Brother MFC 420CN All-In-One InkJet...
924 says that black ink cartridge not installed
Hmmm....that sounds to be an issue with the ink cartridges...
You might be using ink cartridges purchased other than Dell or Staples...since these are the two who sell Dell Ink.
If thats not true, then take out both the cartridges in the printer.
Lets isolate the issue
1. Try only Black cartridge on Color slot(right). If you get Install both ink cartridges error, then its an issue with the Black ink cartridges and if you get message that install Black ink cartridge then its an issue with the prrinter.
2. Now install only color cartridge on Black cartridges slot(left), If you get color cartridge missing then its an issue with the Black cartridges which you are using and if you get install both ink cartridges then its an issue with the black slot on printer.
3. If issue found to be with Black ink cartridge then wipe the Nozzles(bottom) of the ink cartridge with lint free cotton cloth from back to front 5-6 times.
4. Also try replacing the ink cartridges purchased only from Dell or from Staples. Purchased from somewhere else or refilled might not work.
5. If issue found to be with printer, then i would suggest you to purchase new printer then.
Hope this fix the issue
Aug 14, 2008 | Dell 924 All-in-One InkJet Printer
Canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printer cartridge
Open your printer, remove the cartridge, reinstall them back again and close the printer properly and firmly. Start your printer again after that....
Aug 30, 2007 | HP LaserJet 4000n Printer
Cartridge problems
Ref: our live chat - Definitely worth replacing the colour one with a new one - some other people had identical problem and that cured it - they really don't survive not being used very well. :)
Apr 21, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
Epson STYLUS CX5900 Printer Logo
116 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
