Question about Bose Lifestyle 38 System
Disc is stuck in machine - Bose Lifestyle 38 System
  • 5 more comments
  • swaziman Dec 25, 2007
    disk stuck in machine
  • Pointermom Jan 10, 2008
    I put a DVD into the system, nothing is happening and now I can't eject - the door won't even open.  It merely turns OFF the system.  Why?  How can I correct this?
  • LABROAD Jan 16, 2008
    Exact same problem. Disk is stuck. Door will not open - CD/DVD shuts off. Can anyone help? I tried to pry off the door - and now the front panel is off.
  • Anonymous Feb 23, 2008
    cd stuck in player.
  • sudipta16 Apr 23, 2009
    Thanks for the solution drgeri
  • Anonymous May 04, 2009
    what is the solution to a stuck disk in the lifestyle 38?
  • nafdeabhay May 21, 2009
    Disc is stuck inside. DVD drive is not opening. System reboots itself after few seconds.
When the try is stuck:
On a Lifestyle system with a tray that won't open, try this:
  1. Turn off the power.
  2. Unplug the power cord.
  3. Wait at least 5 minutes.
  4. Plug the power cord back in.
  5. DO NOT TURN THE UNIT ON !
  6. Hit the Open/Close button.
This worked perfectly for me!
drgeri
Posted on Mar 02, 2008
If everything fails change cpm unit
Posted on May 18, 2008
Sweet thanks
Posted on Dec 18, 2009
Perfect drgeri
thanks
Movie stuck n apple macbook
Hi
I assume you are saying there is a disc stuck inside your machine?
• Have you tried: using the eject button located upper right on your keyboard? Hold it down for 4-5 seconds.
• dragged the Disc-image to the trash?
• if this fails you can try using the Disc tool located in your Applications folder.
• If all else fails, try restarting the machine while holding down the mouse button. This will eject discs. After the disc is ejected let go of the mouse button and the machine starts normally.
• If even this fails you will have to try manually - the "straighten paper-clip method" There is a mechanical lever at the very side of the hole where you insert the disc that can be used to push the disc out. I would reccomend to check your manual for further instructions on this.
Hope this helps
Feb 06, 2015 | Apple MacBook Mac Notebook
Dvd stuck in tv/dvd combo
There is sometimes a pin hole in the front of the device near the tray, you push something very slender into it and it opens the disc tray. If This doesnt have that feature, you may need to manually dissasemble to retrieve your disc.
Sep 20, 2012 | Sanyo Televison & Video
Dvd is stuck in my ACER laptop how can I get it out
The Acer 5610 has an emergency eject hole to the right of the eject button on the right side of the computer. Find a paperclip and unfold it (or small allan wrench), push the end of the paper clip into the hole until you feel pressure. Press firmly and the optical disc tray should come slightly out of the machine. Grab and pull the tray out (gently). This should work even without power to the drive on any machine tray optical drive, if the tray mechanism is undamaged.
For a slot-loading optical drive, it's a bit trickier. You can try sliding another object into the slot and using it to pry or lift the stuck disc. The safest option is to use another optical disc or credit card sized item and double-sided sticky tape. Put a piece of the tape on the item and then remove the paper from the other side of the sticky tape. Slide the item into the drive with the sticky tape towards the stuck disc (down for most computers). Once far enough into the drive, lower your item and press the tape firmly onto the stuck disc. Lift up and try to pull the stuck disc up and out of the drive.
I hope this helps.
Oct 26, 2011 | Acer Aspire 5610 Notebook
Dvd stuck in machine will not play or open to remove movie
there might be something hooking the disc tray that is prevent it from opening.
The solution to this problem now is to, get a screw driver, unscrew the screws on the player, open the player cover so that you can gain access to the disc stuck inside, remove the disc and check for what's preventing the player from ejecting.
Take care.
May 30, 2010 | Panasonic DVD-S35 DVD Player
We have a cassette stuck in the machine. We are
many a times it happens.......just open ur machine case which is nearer to the disc side and lightly press the disc lock on it ........your disc can be taken out easily
Oct 15, 2009 | Philips VR630 VHS VCR
Disc stuck in machine. took off cover. can see
Find the electrical motor and try to turn it with your fingers, it should move the gears in order to release mechanism. It its stops and no movement, turn the motor the other way.
Sep 12, 2009 | Sony Televison & Video
Disc stuck in factory installed DVD player
needs a new disc changer. Something is wrong internally. You will be able to get them back if you go to the dealership and get an exchange unit. They will send the discs back when they remanufacture the unit.
May 29, 2009 | 2005 Chrysler Town & Country
Philips DVD recorder, (250gb) DVDR3460H. can not remove disk .........
your gonna have to open the machine up the there is a whits tab that lifts the disc up to spin you will have to use your fingers to slde it of that make sure its unplugged and then the white thing will realese
Sep 19, 2008 | Televison & Video
The motor just keeps running after the coffee has completed it's cycle. The only way to shut if down is to turn off the unit. I've tried descaling the unit but that has not helped.
I've had the same problem and found no documented solution or cause. Calling Tassimo was no help. However I've noticed that it usually happens after trying to close the unit when the T disc was not lined up correctly. This pierces the foil in the wrong place. If you run it like that, OR if you open it back up, line the T disc up and reclose; it will spray water and coffee grounds all over. It seems some of the coffee grounds or a piece of foil from the T disc can get stuck in the little switch on the left side bottom of the closing mechanism. This switch indicates to the machine that it is closed. So if the switch gets stuck closed, the machine can think it is closed when it is really open. This prevents a failsafe interrupt from operating which would normally stop the pump and reset the stuck faulty logic in the machine. So the solution is to clean the machine very well in the area around the T discs. This includes removing, cleaning(inside and under), and replacing the part that pierces the T discs. It may look like it is all one piece, but you can pry it up with a butter knife.
Aug 29, 2008 | Braun Tassimo Hot Beverage System - T-DISC...
Bose Lifestyle 38 System Logo
612 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
