Question about Sunpak Cameras
Not really a problem, but a Ques~ "Back in the day" I remember that THE flash to have was the AUTO 30DX or the Vivitar 283. Well, I still have some manual Minolta gear and a 30DX. I just bought another 2 modules for it. Q: Why does one of my MX-2D modules have a factory-made bulge on its side? Q: What's the Diff between the Auto 30DX, the 333, 383,422 and 444 flashes? They all look just like the 30DX. I know the Auto units have the auto sleep/wake feature. Some have more power/features? What benefits are there in buying a 444, 333 or 383 over my aged Auto 30DX? Can I see a chart of features/power for each model? I also own other Sunpak flashes for other cameras, and the CA-3D lets me use the 30DX on my EOS 5 and 10. I will likely be buying more Sunpaks when I get into the digital bodies.Thanks very much.
whatisme10
  • 12 Answers
SOURCE: DSC-S650 - Does not take a photo when auto flash is on...
Try looking in another direction, you half-way press the button wait let go then press it and it should light up with a green dot then take the picture.
Posted on Mar 28, 2008
pishta68
  • 579 Answers
SOURCE: D40 compatability with Sunpak auto 144D flash
the voltage on the flash hot shoe contacts (center pin and rail connector) can be as high as 140V DC and this voltage is backfed into the camera through its hotshoe connector. There are adapters that can be bought that isolate this voltage that go between the flash and the camera, but different camera makers have different ratings for the flash voltage. My Vivitar 220 has 122 volts across the contacts from 4 AA batteries! Canon recommends nothing over 6v but Fuji says 60v and others dont say anything. SLR's used a mechanical trigger, modern digi cams use an electronic trigger. Also Digcams use electronic metering for exposure so they dont take into consideration the addition of another flash unless they do a preflash, TTL metering and the flash unit is capable of recharging in about 1/10th second. YOu may have to do some post processing or set the camera on manual to adjust the exposure.
Posted on Jun 13, 2008
SOURCE: have sunpak dx-8r, need module for nikon
Hi, I am looking into purchasing a Sunpak DX 8R, it includes the NE-3D Module for the Nikon F3 (If this is what you are looking for) which I have no use for. If you are interested, please advise,Thanks
Posted on Oct 16, 2009
  • 65 Answers
SOURCE: Sunpak 383 problem
Try to trigger it by shorting Center of shoe mount and the side terminal with a small wire.If it is firing the flash is ok.
If not there is open connection in the sync jack ,due to repeated inserting of sync chord.The springy part inside is not going back to its normal position.
You can fix it your self by opening it(adapter only)
.If you are new to this take a photo of the wiring immediately after opening the shoe adapter to see the position if any wire breaks later on.
Do not give up .383 is great flash
Posted on Mar 05, 2010
  • 102366 Answers
SOURCE: i need a manual for a sunpak auto 30dx
You may download a copy of the manual here.
Posted on Nov 09, 2012
Vivitar 283 on a digitial camera?
It depends on the variant of the 283. Take a look here.
Aug 27, 2012 | Vivitar 283 Flash
Can i use sunpak auto 30 DX thyristor to nikon d7000?
According to this list the 30DX's trigger voltage is borderline for use with digital cameras. You may be able to use it with no ill effects, or it may fry your camera. It depends on the particular unit.
May 12, 2012 | Sunpak Nikon Auto 30dx Thyristor Shoe...
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
Hi my name is Curtis can you tell me IF my Vivitar 283 flash will work on my c-750 Olympus, TTL camera it have an hot shoe,but flash don,t fire. I have talked to Olympus about it(on answer). I took it to a...
No the 283 is not compatible with your camera. The 283 is manual only and not TTl. The canon flash is also not compatible with your Olympus. You need an olympus compatible flash.
Nov 16, 2009 | Vivitar 283 Flash
Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Jan 06, 2009 | Vivitar 283 Flash
Battery holder for Vivitar 283 is broken. Can I get a replacement
I think there are some listed on Ebay-check it out.
Dec 27, 2008 | Vivitar 283 Flash
Batteries
I use Duracell 2650 mAh rechargeable AA's with my 283 all the time. You may read that 1.2v Duracells or other rechargeables will not work because of the slightly lower voltage (alkalines are 1.5v).
I believe the problem lies not with the voltage, but is due to the slightly fatter profile of the rechargeables that causes a tight fit in the Vivitar battery pack. I find that, after inserting all four (the last will go in really tight), I need to give each cell one more firm push so that it seats properly into the battery pack.
Good luck.
Caruso
Oct 13, 2008 | Vivitar 283 Flash
Mains adaptor for Vivitar 283 flash.
http://www.hiviz.com/activities/guidebook/sensor.pdf....perhaps this is a help.. not sure..
Sep 06, 2008 | Vivitar 283 Flash
Vivitar 283
if you have PC connector for the camera or a hotshoe.
May 10, 2008 | Vivitar 283 Flash
Cameras Logo
Top Sunpak Cameras Experts
Doberman
teddyboy
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
