Question about Mitsubishi WS-55809 55" Rear Projection Television
The blue red and green lights are not aligned causing ghosts of color
    Habit-Forming:
  • 32 Answers
Sounds like a convergeance board has gone bad, common on these projection T.V's the IC's are around 100 bucks and shop can do it for you for around 400 to 500 dollars
Posted on Oct 08, 2009
Slight ghosting and color alignment problems
comvergencia that reviews the misaligned with the remote control and traps
Jan 05, 2010 | Televison & Video
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Ghosting of the image
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Red and blue ghosting,
*Screen Looks 3-D
*Colors wont align
Problem #2
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Color ghosting or shadows
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Ghosting - colored shadows - guns out of alignment?
*Screen Looks 3-D
*Colors wont align
Problem #2
Nov 08, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Ghosting in Red, Green and blue
*Screen Looks 3-D
*Colors wont align
Problem #2
Sep 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergence problem, blue ghosts
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2008 | Samsung PCN5425R 54" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
