My 1996 GMC 2 door Yukon GT has very little AC fan power. The Air comes out cold but the fan has no power and the interior is quit large. What can I do ?
    Problem Solver:
  • 13 Answers
The evaporater in the dash may be clogged/coated with dirt and dust and the air can't flow through it properly.
Posted on Oct 09, 2009
My heater don't work in my 1999 GMC Yukon all it dose it blow cold air
Blend Door Actuator Replacement 1999-2007 Chevrolet ...
? 2:25
https://www.youtube.com/watch?v=Eqf-H3COtSo
Nov 4, 2013 - Uploaded by 2CarPros
My problem in my 2004 chevy tahoe is that it will not blow out of the dash or ... onto the vent door gears ...
GMC Yukon AC and Heat Questions - Car Forums at Edmunds.com
forums.edmunds.com > Chevrolet > Chevrolet Suburban
Jul 20, 2010 - 30 posts - ‎16 authors
I just don't get why that doesn't work right in the first place. ... I have 99 Yukon that has a problem with the front air. .... $55,000 for my GMC, I guess expecting cold air when we push A/C and getting 90 degree blast ... 2001 Yukon XL 1500 Front heat & air fine, rear ac blows hot as if heater is on in all settings. More results from forums.edmunds.com
Nov 18, 2015 | GMC Cars & Trucks
2004 GMC Yukon Denali - Squealing within the interior
high pitch squeel usually comes from the cambelt
Jul 24, 2008 | 2002 GMC Yukon XL
No heat just cold air
Is the gauge showing the engine is warming up to normal temp ?
Are the heater hoses getting hot ?
If the heater core is getting hot, it could be a blend door problem. The blend doors direct air thru the heater core and the ac evaporator among other things.
Dec 06, 2012 | 2005 GMC Yukon
My 1996 GMC Yukon does not have any heat, just blows cold air what could it be
Check coolant level. if ok then see if engine comes up to temp. 190+ at thrmostat housing. If not, replace thermostat. If thermostat is ok, feeel heater hoses. If one is hot , and the other cold, then remove both and flush heater core. If both are hot, suspect blend door problem in heater box. probably need pro help for that.
Dec 18, 2010 | 1996 GMC Yukon
2004 yukon ac blows hot air on drivers side with
EASY FIX-- your blend door actuator has a grease drip inside on a sensor. It's a easy fix. I just fixed mine in 20 minutes. See how to here==> http://www.tahoeyukonforum.com/forum/showthread.php?t=17741
Jul 22, 2010 | 2004 GMC Yukon
2003 gmc Yukon 5.3 ..2WD air conditioner blows
A vacuum hose that controls the little door that switches where the air blows from is off, its gonna be a real chore the find which one and take the dash out to get to it, but you might get lucky and be able to look underneath the dash from the passenger side and actually see it, good luck
Jun 19, 2010 | Cars & Trucks
How can I determine if my compressor is out on my
If you still get cold air out of the rear vents but the front only blows hot air you may have a bad temp door actuator in the dash, it may be stuck on hot and not able to move to cold air. However if you are low on freon with a truck that has front and rear ac then there will be a temp diff between the two. If it is hot air out the front like the heat is on then you have that actuator problem but if it is cool air about the same as the outside air temp then you may be low on freon.
May 23, 2010 | 2004 GMC Yukon
Air Conditioner Problem
the most common problem here is a defective air temperature control blend door actuator, this is what moves the door that controls air flow across the heater core or the ac evaporator core, to replace this requires u remove the dash assembly.
Aug 13, 2009 | 2005 GMC Yukon Xl Denali
Blower fan on a/c quit blowing in front but still blows and blows cold air in back
first off make sure you have no blown fuse. but front blower motor may be bad. if it does not work in any speedyou can check for power at the wires going to the blower. under dash on passenger side
Aug 10, 2009 | 1999 GMC Yukon
Heating & Cooling Logo
177 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
