Question about Canon iP4500 Photo Printer
I have an iP4500 printer which will not print pdf files, nor will those files display in Safari. Any ideas?
  • 2 more comments
  • davevirgi609 Oct 08, 2009
    The drivers are ok and up to date. The error message is "Unable to open raster stream - : No such file or directory"
    Unable to open raster stream - : No such file or directory us the message - drivers are all ok
    Unable to open raster stream - : No such file or directory is the message - drivers are good
    added those drivers, still no dice :-(
    President:
  • 1,653 Answers
Some PDF files wont print as they have print capability disabled by the author. Try printing the following PDF document as a test.
http://h10032.www1.hp.com/ctg/Manual/c00238864.pdf
Try setting PDF to open in the Adobe Reader application, not in the browser, then print the document from the application.
If you need Adobe Reader 9.1 you can download it from the following Adobe link
http://get.adobe.com/uk/reader/
Windows Users
Click Start - Control Panel – (Hardware and Sound) - Printers.
Right click on your printer name and select Properties
Click on the Ports tab
The current port setting for your installed printer is set to FILE: Print to File which causes forces printing the document to a file on your hard drive instead of to the printer port. Scroll through the list of available ports to find the port that your printer is connected to, typically USB, LPT1 or a network location, and check the box next to it then click OK. Then print a PDF and it should now print OK.
Posted on Oct 08, 2009
    Brigadier General:
  • Canon Master
  • 3,614 Answers
Did you got any error message when you try to print?? Update the printer software and make sure it was selected a the default printer on your browser if you a multiple intalled printer driver...
Hope this helps
  • micromaster
    micromaster Oct 08, 2009
    uninstall driver and download the latest driver from HERE
    Let me know
Can the Printronix P7005 PSA3 print PDF files?
Sounds like your printer may need IPDS, I'll need to see a configuration page from your printer in order to determine whats on it. you can email me it at rcardenas@mrp.to
Apr 09, 2013 | Printronix LineJet® P7005 Printer
Canon iP4500 colour management
Try this setting. This might be different but try to point some similar preferences and steps then you can give it a try.
Open Control Panel (I'm assuming that the OS is Windows XP) click on Printers and Faxes.
Right click the Canon iP4500
Click Properties in the drop down menu.
Click on the tab Color Management
There should be a list of color profiles if the drivers were installed properly.
They are-
(Generic)
(Matte Photo Paper)
(Photo Paper Pro)
(Photo Paper Pro Matte)
(Photo Paper Plus Glossy)
The last profile is the one you want. Just above you will see the choice of "Automatic" or "Manual". Click on Manual and this force the printer to use the highlighted profile for all printing jobs.
Now click on DEFAULT.
Go back to the main Properties page and click on the General tab.
Near the bottom you will see "Printing Preferences"
click on that.
You should now be in a Canon ip4500 Printing preferences window.
Look for Print Quality and click "Manual"
Click on "Set"
Click on "Diffusion" and just above that there is a slider that should be all the way to the right.
Click "OK" to save the settings.
Now just below you will see "Color Settings"
Click "Custom" and then "Set"
Everyone sees colors a little different but the following settings print a photo that folks I show them too really like the balance of.
Cyan 4
Magenta -12
Yellow 0
Black 0
Intensity Slider in the middle
Enable ICM not checked (disabled)
Print Type set to Photo (you might want to try the other settings here to see how the prints look to your eyes)
Brightness Normal
Click OK to save settings and return to the Main Menu.
If you now go under the Profiles tab you should see you new profile there.
You can give it a special name like "Canon Excellent Profile Settings" clip_image001.gifor some other easy to remember name. This is the profile you want to use when you print a photo.
That is it...simple eh?
Now the other important part is in PhotoShop/PS Elements. Open the program and then open any old photo.
Under File, scroll down to Print Preview and click
If not open, click on "Show More Options"
Bring up "Color Management" in the box just below the "Show More Options"
For "Source Space" click ""Document"
This setting depend on the profile you shoot in, either Adobe RGB or sRGB. You choose the one you use.
Below that there is a setting for "Print Space"
You want to match that to your source, whether Adobe RGB or sRGB.
For the "Intent" letting I choose Perceptual.
Then click "Use Black Point Compensation" and that is it. Ready to print
Aug 08, 2008 | Canon Pixma iP4500 InkJet Printer
Canon ip4500 problematic with win 64bit - seeking solution
Go to a 64-bit machine on the network and copy the 64-bit driver files to the machine
From the 64-bit machine, open Windows Explorer and browse to the 32-bit server
Open the Printers dialog seen via Windows Explorer.
From the Menu bar, select File > Server Properties, select the Drivers tab and click the Add button.
In the Add Driver Wizard, tick the x64 Processor checkbox, and untick the x86 checkbox.
Click Next, then click Have Disk and browse to the 64-bit driver on the local 64-bit machine.
Complete the Add Driver Wizard.
for more help visit CBR Tech Solutions
Dec 07, 2012 | Canon Pixma iP4500 InkJet Printer
Canon IP4500 repair manual
There are three options for you:
1 -- Here is a copy of the manual for free http://www.gondack.com.ar/media/useruploads/files/ip4500-ssm.pdf 2 -- Go to this web page and register for the forum, then post a comment requesting the manual like everyone else and a member will email the manual to you. The last request for a copy of the manual is a few weeks old. http://www.fixyourownprinter.com/forums/inkjet/58346
3 -- Go to the service manual website about Canon (not a Canon site) and purchase a copy for $8.00 USD. http://www.canonservicemanual.com/canon-ip4500-service-manual
Dec 03, 2011 | Canon Pixma iP4500 InkJet Printer
My canon ip4500 printer has just came up with service error 5c20 what do i do?
This is a pump roller error. Needs a new board.
I have attached link to the Simplified service manual for your printer.
Part numbers included and ALL Epson Service codes for that model.
Jan 26, 2011 | Canon iP4500 Photo Printer
My canon iP4500 will not use black ink on photopaper. If I tell it the paper is plain then it prints fine. If I tell it the paper is any type of photopaper the colours are great but there is no black ink...
If you set Plain paper with Greyscale printing, only the black Pigment tank is used.
If you set any other paper type, only the 4 Dye tanks are used - even if set to Greyscale.
Dec 09, 2010 | Canon Pixma iP4500 InkJet Printer
How do you print pdf files from adobe reader
In File menu, select Print. Or Uuse the CTRL P key combination. If the tool bar is displayed click the printer icon.
Jan 26, 2010 | Adobe Acrobat® 8.0 Standard Full Version...
Canon iP4500 not printing yellow
take the print head with all the cartridges still installed out of the printer. take a soft microfiber cloth and gently wipe the exposed surface on the bottom of the printhead. You should get some ink to wipe off the printhead.. reinstall and retry your printing.
May 31, 2009 | Canon Pixma iP4500 InkJet Printer
Can't print a pdf file
Sounds like you are using the PDF printer as your selected printer - this is for creating PDF files in which case you would give it a name.
If you have a PDF file open, simply select your printer (1610) as the printer to print to as with any other documents you print.
Dec 29, 2008 | HP PSC 1610v All-in-One Printer
Canon iP4500 Photo Printer Logo
646 people viewed this question
old marine
old marine
