Question about Fuji FinePix A340 Digital Camera
Error write i got smoe advice from someone online they told me to format my camera which i did .it would then let me take a pic but only 1 pic.and then i have to format again can you help please
  • Anonymous Feb 03, 2008
    same problem
  • Anonymous Feb 08, 2008
  • 2,985 Answers
This may help
Posted on Dec 26, 2007
Plz told me about that why the above camera shows the error that "HDD parmat error" when it on
Hi Imran Hussian, the error( E:31:00 ) HDD format error shows on the display when the camera is turned ON. it can be solved in three ways. 1) try to format the HDD under MEDIA FORMAT SETTINGS, if it works OK or 2) try to reset the camera by pressing the RESET button and if doesnt works 3) contact service support.
Aug 19, 2015 | Video Cameras
Sony dsc-s730 format error
Download the pics to your computer using a separate memory card reader. Then, format the card in the camera.
Sep 22, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Took my Olympus FE240 to photo shop to get prints. Would not work and was told files are saving in jpf format and no other solution offered. Can you help?
Not sure why it did that but it is related to the baseline JPG I cannot see any documentation on Olympus about this.But not to worry
Get the above program loaded onto your PC grab pics from the camera by using an card reader aqnd then run them through the converter.
JPF is an advanced from of JPG Check the settings in your camera to see if you can chane the format to Jpg.
please rate our help to keep the servive online
Aug 30, 2009 | Olympus FE-240 Digital Camera
Only partial picture on frame
it could be a shutter problem. however if it is only when using a flash it would be sync. for flash photography most cameras have a shutter speed that they sync at normally 1/60
May 26, 2009 | Minolta Maxxum 5000 35mm SLR Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
C:13:01 Format error
don't worry.i got the solve this problem.because all this happened due to the old files on memory card which corrupted you need to format the memory card.then insert the memory card on digital camera.your camera will work finely.
Nov 06, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Camera lenses and errors
the cover lens got erased and when i try to make a pic. the camera shows a hand sign.what wl i do?
Aug 22, 2008 | Cameras
Problem Downloading pics from Sony T-100
check your plugs and leads to make sure there are no breakages or faults on them , and check to see if you have a folder to import your photos to , you may need to creat another folder that you can open from a graphics package and save the photos as a wmf or bmp file or what ever is most appropreate formatfor the package that you are using there are heaps of different ones , some graphics programes need to be told which format to save photos in and which format to view them in
good luck
Jul 06, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Card NO formatted
If u get a lock(A small switch on the left side of the card) on ur card try changing its position.Move it to other side.
Oct 25, 2007 | Pentax Optio E30 Digital Camera
Disc Error
the c:13:01 is the error code. I was researching this same thing on my camera. It 'magically' fixes itself after anywhere from 1 minute (turn off, count to 20 and turn back on)to 1 month later. This time, I lost photo-ops with my kids and their cousins. Apparently, this is a loose connector - see link- and you can fix it by 1) smacking your camera around a little (no joke, this knocks the connector back, for a little while or 2) sending it to Sony for repair (about $350) or 3) follow this guy's suggestions and fix yourself. I haven't lost any actual photos, except the first time when this happened. Since then, I've put the CD in the computer and I've been able to pull off the pics. Can't use the CD again though, even if it's not full. The camera must mark the CD somehow to avoid overlaying photos(?). Anyway, here's the link and good luck :)
Oct 21, 2007 | Sony Mavica MVC-CD200 Digital Camera
Fuji FinePix A340 Digital Camera Logo
32 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
