Question about Sony Playstation 3 (PS3) Console
I used the hdmi output yesterday now im back to the old cables now i have a black screen
  • 416 Answers
You have to go into your ps3s settings menu and switch back to the alternative input for it to work
Posted on Oct 08, 2009
Ps3 goes to black screen then to normal
It could be as simple as your video cable going bad. Check to make sure the wire is in good shape and that the contacts and connections are secure.
I would say try using it with an HDMI cable (if possible) and see if the problem persists. You can also try and hook up another device (DVD player, camera, PS2, etc) to the TV input you are using now and see if it is the TV that is giving you trouble.
Jul 09, 2012 | Sony Playstation 3 (PS3) Console
MY PS3 is hooked up via HDMI and has always worked fine. All of a sudden i went to turn it on and there was nothing but black, it detected a signal, but it was just black.
Hi there, Have you switched cables or changed any of the video output settings on the ps3 or your telly? Just double check all the settings and that the cables are connected properly and are not damaged. If you have another cable try that to see if you still have a black screen or try on another telly with the same cable to see if it's the cable that the problem is? If you using a standard cable to try on another tv, you will have to reset the video output so it will work, to do this simply hold down the power button on the front of the ps3 until it powers off again and this will allow it work on a standard tv with standard cable, and to switch back to hdmi just connect with hdmi. Cable to HDTV and the ps3 will detect the cable and ask if you want to use these settings. Hope this helps
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
European PS3 HDMI stopped working and AV video is very messed up
Try holding down the power button down for about 10 seconds (until you hear another beep) when powering on. reset video output and just set it up again. this is a diagnostic screen that most people dont know about
Nov 04, 2009 | Sony Playstation 3 (PS3) Console
Blue no signal screen in the middle of playing a game - ps3 hdmi
Have your tried a different plug HDMI plug on your TV? Maybe bring your PS3 to a friend who has HDMI and try it on his TV. What about a diffferent HDMI cable?
Could also be your HDMI on your PS#, but try these other simple tasks first.
Good Luck
Sep 08, 2009 | Sony Playstation 3 (PS3) Console
Black and white display screen
If you have an HDTV use HDMI or component to connect to get colour...if you have an SDTV and use the RGB cables unfortunately the PS3 will output NTSC signals for JApan/NA and your SDTV will accept PAL signals (EU). THere may be an adapter, but if you have an HDTV this problem should solve itself via HDMI/component cables.
Aug 29, 2009 | Sony Playstation 3 (PS3) Console
Ps3 start up promlem
so if you have ever had your ps3 connected to HDMI (HD cable) before, and your forgot to change it back to the normal cords that came with the game (yellow, white, and red) then you will have to connect it back up to the HDMI and go to the Display Settings and change your video output to the one that came with the ps3 (which looks like just one yellow in the settings.) then after you do that then the screen might go black if your HDMI and regular cable are on a deffirent channels, so you turn to the channel that the yellow white and red cable needs to be to, then it will show the screen and ask you if you want to leave it at this setting with this video output/cable then you say yes then your good to go.
Oct 09, 2008 | Sony Playstation 3 (PS3) Console
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
It POWERS ON BUT HAS NO PICTURE,
Okay, I am now going through all the unsolved problems for which previously I had the same problems and now posting our solution. First, if you have no pic due to swiching of the cables (ie, cable av, hdmi) WHENEVER you switch your cable output, the ps3 also switches it's output. Make sure when there is no picture due to this problem to turn off the game console, then turn on, hold down the power button for approx. 5 SECs, there will be a BEEP. Let go of power button, the ps3 has then switched back to the output it is currently plugged in and will work. (ALSO sometimes you have to have ONLY the ps3 and tv hooked up) Hope this helped. I know how stressful this can be!
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Sony Playstation 3 (PS3) Console Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
