Question about Phonic Music
I have a Phonic mr4283d mixer and I don't have the power supply. can you tell me where to get one or tell me what the requirments are for it so I can make one up myself? I would like to get a schematic for the board can you hep me with that also? Thanks Brad
  • nascar2 Oct 08, 2009
    I did contact the manufacture with no help and I know you are not a parts service but I thought you could tell me where I could get this information.
    Genius:
  • 1,043 Answers
Like most audio mixing equipment Phonic uses a proprietary 3 pin connector for their mixer. As power supplies can easily introduce background hum and other interference, it is important to ensure that you use the correct power supply from the manufacturer of your unit. They will be properly grounded and shielded to ensure they do not cause any issues. Depending on the size of the city you live in you might be able to find a local source for the replacement. If not then go to Phonic's webpage at http://www.phonic.com/index.php?ssolang=en. If you look under the Support heading you will see "Contact Us". Fill out the form with your information and your request for the power supply. You can also request a copy of the schematic. Some manufacturers have no issue with supplying schematics while others do; there is no specific information on their site regarding that issue.
Posted on Oct 08, 2009
    Top Expert:
  • Phonic Master
  • 76,673 Answers
We are not a part's service, we have no way to find these parts, please contact the manufacturer for further help
How to connect speakers to phonic mr3243 mixer
You would connect the xlr left and right outputs to a power amplifier and then the speakers to the power amp. The mixer will not drive a set of speakers by itself.
Jan 19, 2015 | Phonic Music
How many volt , ac.or dc. for power supply phonic MM1202 mixer
I tells the power supply model numbers on the back of the unit above the power connector plug. It doesn't tell the specs as of how many amps but does describe several voltages of AC it would work on and also gives several model numbers of the correct power units that are sufficient. If you don't use one the recommended units, it could malfunction and give extra static noises caused by improper filtering of the power. It shows on page 8 of this manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=39&ved=0CHkQFjAIOB4&url=http%3A%2F%2Fsoundhouse.co.kr%2Fsoundh%2Fcatalog%2FPHONIC%2Fmixer%2FM-U-1-2-0-2_1-2-0-2-X_om.pdf&ei=QPdbUaX3K4zA9gS11IFY&usg=AFQjCNGoMutp27pESma_-Mw36637hlmHOA&sig2=8J0-4rb6sHlit-OdKlIFbg
I hope this helps you.
Mar 31, 2013 | Phonic Music
Low signal from mic to computer
If your using a condenser mic, make sure you are supplying it with phantom power. Use the faders to cut/boost for volume control
Mar 29, 2011 | Phonic NEW PHONIC SONIC STATION 22 MIXER...
Phantom power will not wor on my phonic 620 cd jacks will work but when i plug in a mic it will not work help
I assume you are using CONDENSER microphones, as these are really the only ones that can use Phantom power. Also do NOT use any MONAURAL connections to MIC jacks while using Phantom power.
Dec 12, 2010 | Phonic NEW PHONIC SONIC STATION 22 MIXER...
I have a Phonic Helix Board 24 firewire MK2 When i open it all the peak led stays open I think the power suply is busted I need an expert
The power supply uses three, 3 terminal regulator chips. You should find +/- 15 volts and +5 volts DC from those. There are two fuses, one for each polarity. If one of those is blown, that would cause the problem and one would need to find WHY it blew before replacing it.
You need to find a competent electronics repair person.
Nov 02, 2010 | Phonic Helix18fw 18 Channel Mixer with...
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Music Logo
163 people viewed this question
Top Phonic Music Experts
Ben Armstrong
NOEL
NOEL
Are you a Phonic Music Expert? Answer questions, earn points and help others
