Question about Whirlpool Duet GHW9150P Front Load Washer
Control locked light is on and doesnt let me do anything....i tried unplugging and it still stays on
  • 5,911 Answers
The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set by leaning against the panel, or following power interruptions due to brown outs and black outs. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Posted on Oct 08, 2009
Control lock stays on
Try holding for 3-5 seconds should unlock controls.
Jan 20, 2014 | Maytag EPIC MFW9600S
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light
press an hold three seconds
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
Duet GHW9150P Front Load Washer: control locked light stays on ,wont let you do any...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
03 grizzly 660 diff lock light stuck on.
Diff lock light on, but 4X4 & diff lock work fine, but light is always on. I tried unplugging both plugins from front diff, but light still stay on. What do I do?
importales@yahoo.com
Aug 27, 2009 | 2004 Yamaha XT 660 X
Controls locked status light stays on and dryer cannot be used
To enable the control lock feature:
Press and hold the CYCLE SIGNAL button for 3 seconds. The
CONTROLS LOCKED icon lights up, and a single beep tone is
heard. To unlock, press and hold the CYCLE SIGNAL button for
3 seconds. The indicator light turns off.
Jul 11, 2009 | Dryers
Control locked light on
Try holding down the end of cycle button for at least 3 seconds.
Jun 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Problem with wf440 hotpoint
check to see if door is locked may be interlock
Dec 19, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Flashing Control lock light
Press 'options' & 'select' for 5 to 6 seconds, controls may unlock (depending on your model) If it is a key you see, it is the child lock.
Apr 29, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
