Question about Sanyo PLV-Z3 Multimedia Projector
Sanyo Z3 Blue Color Problem
I have a neon blue color starting to come through in the middle of my screen. Its getting larger and brighter each day.
All of the sudden tonight, black bars came across the screen while I had my XBOX 360 running through HDMI. The menus for the unit did not have the black vertical bars running through them though. This problem could be unrelated but I figure its worth mentioning.
  • 43 Answers
Jahting is right, The "blue" lcd module is burned. Easy to replace.
Here is the service manual for your projector.
There is a helpfull troubleshooting guide in it.
http://yama.co.za/forum/index.php?topic=147.0
Posted on Dec 03, 2009
  • 70 Answers
The LCD Module of your projector in blue panel is burn so that you can it larger and larger. replace your lcd blue panel. and also the mirror inside your optics.
Posted on Oct 08, 2009
  • vicente muñoz
    vicente muñoz Oct 08, 2009
    the LCD Module of your projector in blue panel is burn so that you can it larger and larger. replace your lcd blue panel. and also the mirror inside your optics.
My 55in Sanyo has white lines top to bottom of the screen the color of the screen changes while cable is on and then turns black with big white and blue lines in the middle when jst the tv is on
T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 18, 2015 | Sanyo Televison & Video
Have a Sanyo big screen tv but need need to adjust the color, to yellow!
Need to know if older set with picture tubes---turn color off--if yellow screen you have a loss of blue of some sort--red and green will give you a yellow screen. If set has the 3 picture tubes look inside in the lens to see if all 3 have a image---little or no blue means a problem there.
Oct 15, 2012 | Sanyo Televison & Video
After replacing the bulb, we had a blue colored shape in the middle of the screen, it has now changed to the color yellow and has become larger. I am curious as to what that means?
I don't have a solution but I just purchased the exact same thing which arrived a week ago and I have the same problem. I just have a blue shape in the middle of the screen shining through. I called SONY but they were closed for the day. Trying to find a solution on-line. Maybe we got a bad batch of lamps??
Oct 10, 2010 | Sony (XL-2400) Projector Lamp for...
Blue color on bottom screen and it is getting
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. You can find it here: http://www.discount-merchant.com/SONY-1-788-155-21-p/1179590.htm?Click=48173 Have a blessed one!
Apr 16, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue circle of color in middle of screen
This is your Light Engine that is defective. They usually cost in excess of $700.00 to replace. Not the Lamp.
May 02, 2009 | Televison & Video
Blue color flowing from side and bottom into picture
Sony tech support (no charge) said it was definitely not the lamp.
Their suggestion- By unplugging the TV for a minute then turning back on, the blue color was substantially but not toally reduced.
Perhaps there is an electrical charge building up distoring the color by having the TV in the ready mode for too long and by unplugging, the charge dissipates?
No other phone solution recommended other than calling for repairs.
Mar 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sanyo PLV-Z3 Multimedia Projector problem
This could be due to one of the three filters that are easy to change - download the free pdf service manual - not the user manual - it is very descriptive and the filter is about $120 from Sanyo.
Jan 16, 2009 | Sanyo PLV-Z3 Multimedia Projector
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Blue dots and blue color
my sony is 4yrs also it has blue dots on the left side from top to bottom and a blue blob on rt. bottom corner no longer under warr. please send repair solution.
Jan 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue Shades
There may be a failure starting on the video or matrix driver boards. This has to be verified at the service center. The fix will be done by swapping in a new board to replace the failing one(s), and re-doing the factory setups to make sure that the default colour temperature and levels are correct.
I suggest that if the set is out of warranty ask for an estimate first.
Jerry G.
Oct 26, 2007 | Sanyo DP42746 42 in. Plasma Television
Sanyo PLV-Z3 Multimedia Projector Logo
861 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
