Question about Nintendo DS Console
Nintendo DS Power problem powers on but goes straight off
Have just replaced broken Hinge case and screen cable, put it back together, Nintendo DS Power problem powers on but goes straight off
  • youngxrose Dec 30, 2008
    My son's DS has the same problem. it charges and when we turn it on, it turns off right away. i went to nintendo.com and it says $75 to get it fixed.
You may have not put a connector back on properly....
http://www.instructables.com/id/Replace-the-top-screen-of-a-Nintendo-DS-without-o/
Go there and read it through - there are also other walk-throughs for repairs on this site that are very thorough.
Best of luck
Posted on Dec 25, 2007
    Problem Solver:
  • 9 Answers
Ds sucks go get a psp then i will talk to you
-Psp master
Posted on Dec 24, 2007
Broken in half got new shell don't know how to put together
much of it is pretty straight forward, the only hard part is putting the ribbon cable thru the hinge for the top screen, without ripping it, best thing to say is put the ribbon cable in first, then the wifi and mic cables (black and white), rest is pretty straightforward.
Apr 17, 2009 | Nintendo DS Lite Console
Touch screen not working
Well, did you call nintendo to see if you were under warranty?
why did you try? do you have a degree in engineering? Regardless, now you have voided your warranty. Call them and see.
Jan 22, 2009 | Nintendo DS Lite Console
Fualt on DS
By putting the case together you've short circuit the black wire with the powerconnector. Open the bottom case and check the wire. Check Fuses F1 and F2. 99,9% change that one of them is blown out. Replacements can be found on the Internet
Aug 14, 2008 | Nintendo DS Lite Console
Onceturned on, the green light goes on, the touch screen flashes white, then it all turns off.
You might only have a loosen screen ribbon cable.
If not careful while taking out the top screen ribbon you can damage it causing blank screens and finally the DS wont work.
The solution to a broken top screen ribbon is to replace the whole screen in DS lite or buy the ribbon cable in the DS fat and replace.
If the broken top screen ribbon is caused by broken hinge then you should replace the shell also to avoid other broken screen.
May 22, 2008 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
Won't power up
there is something not properly plugged into the logic board. try opening the ds and make sure all connections are secure
Mar 03, 2008 | Nintendo DS Console
Replacing broken nintendo ds screen
there is a little black bar across copper colored connection wires leading into the tan connection box...lift it up ever so lightly by placing fingernail underneath... see http://www.instructables.com/id/SED515GFA0CVIFN/
warning... I have been replacing cover this evening for 3 hours only to find the right hinge piece that inserts into the lighted power tab doesn't rotate.... IE this was what caused the hinge to break in the first place and this torque/force problem causes the left hinge to break which is posted all over the internet and seems nintendo would have replaced all that for free anyway....I was searching this issue when I found your post SSLong hth
Jan 04, 2008 | Nintendo DS Console
Will not power up after changing the case
I found this on ebay after a lot of searching forums and other sites, and it worked for me!
"If you are one of the unlucky ones, LIKE me, you may find after taking it apart,and then putting it all back into the new case, that when you power up, bottom screen flashes, and nothing... DONT panic.. I did.. tried looking for help on the web and couldnt find any. It just means you, like me havent pushed one of the Ribbon cables fully in... took me a while to work it out, just unclip the ribbon cable again, and with both fingers gently push it all the way in, you will feel it slide into the socket more than it did before. "
Good luck Duca
Sep 14, 2007 | Nintendo DS Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo ds hinge fix
Well, you can buy a hinge from a lot of places, but the wire that broke, you are going to have to try and fix the wire, get it connected again so that it will work. The only other solution is that you will have to send it in to get fixed.
Aug 08, 2007 | Nintendo DS Console
Nintendo DS Console Logo
1,203 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
