Question about Hobart D340-6009 Mixer
Wiring diagram for a Hobart D340 40qt mixer
I picked up a Hobart D340 mixer for cheap. Only problem is...someone tried to rewire it from a three phase set up to a single phase. Most of the wires are disconnected. Would like to attempt this fix without callling the professionals.
  • 80 Answers
I read in the manual that the wiring diagram is located on the inside of the top cover. check it out..
good luck
Posted on Oct 08, 2009
Can I rewire a Hobart VCM-25 Mixer/Cutter 460v to run on 220/240v?
There is likely a nameplate with a wiring diagram inside. Without being familiar with the specific model, I can't tell you where. If you can find it, it will show both 460 and 230 volt configurations. Regardless, you will find inside the wiring box (where the conduit comes into the mixer) there are four wires corresponding to two windings - for 460 volts, the windings are wired in series. For 230 volts, they should be wired in parallel.
Jul 16, 2014 | Hobart Food Mixers
What is hobart h600, single phase or 3 phase?
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Jul 09, 2014 | Hobart H600 Stand Mixer
Hobart three phase mixer is spinning the wrong way
Sounds like the polarity. Easily corrected by swapping the red and black position of the wires inside the plug. Make sure there are no other power sources feeding the unit before removing the plug.(the white and green wires should not be moved. Easy way to remember wiring a three phase plug. Most are labeled on the inside of the plug with GXYZ. G is always the green ground wire. X-red (Indians were here first), Y- white ( then came the white man) Z- black ( then the black man)
Sep 04, 2013 | Hobart Food Mixers
HELO I recently purchase a 460V H600T hobart mixer 2.5 AMP/ 3 PHASE but unfortunatly our bakery only provides 110V or 220V what are my option??
The machine can be internally rewired for 220 3 phase. Call your local Hobart office and have them come out and take care of it.
Sep 05, 2011 | Hobart H600 Stand Mixer
I needed to know the PH for a h600 11344142 Hobart mixer... And is it a single Or 3 face??
Hello Jbabajanov,
I understand that you want to know about the HP (Horse Power) of a H600, 60 quart mixer and weither it is a single or three phase.
All H600 Hobart mixers are equiped with a 2 horse power motor.
As to wether it is single or three phase you will need to look at the service tag of the machine. If is listed on it weather it is single or three phase.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Hobart H600 Stand Mixer
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
Only have two phase power power company refuses to install three phase can i run my hobart h600-t mixer serial#31-1068-582 ml# 104385 with just two phase?
first thing, there is no 2 phase pwr. there are only single phase or three phase.you have 2 choices either you can convert mixer from 3phase to 1phase which will be expensive, or you can get a rotophase which will make 1phase pwr to 3phase pwr to run mixer, dont go with static phase inverter, only the rotophase inverter
Jan 19, 2010 | Hobart H600 Stand Mixer
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
Hobart D340-6009 Mixer Logo
889 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
