Question about Canon PIXMA MX310 All-In-One Printer
Paper cannot be fed into printer. When i put paper in the feed area and try to print something, the right side of the printer takes the paper, and the left side of the feed does not take the printer in. HELP?
    President:
  • 787 Answers
Check the paper feed from left side.May you have drop something inside which blocking the paper.
Posted on Oct 08, 2009
Paper jam/no paper fed
make sure the photo paper is in glossy side face down,
set the paper type to photo.
If it keeps jamming it's because the paper feed is probably dirty and not taking the paper properly
Mar 24, 2010 | Brother DCP 130C All-In-One InkJet Printer
Paper pickup not moving
Have you set the margins?????
If you push the left margin over, it may help.
Jun 08, 2009 | Konica Minolta magicolor 2400 Laser...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Won't take paper
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2, and press the <Open> button.
  9. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click to return to step 2 above.
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Paper fed
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Mar 08, 2008 | Lexmark P915 InkJet Photo Printer
Printing problem with MFC-665CW
1. Take paper tray completely out of the machine.
2. Remove the rear cover, clean the paper pick-up roller.
3. Put rear cover back, put paper tray into machine.
4. Copy a blank page for paper feeding test.
Jan 23, 2008 | Brother Multi-Function Center MFC-665CW...
Paper jam
Well, if you could put that disengaged gear back all by yourself, then put a little "grease" or "oil" on the right side of the paper tray are mechanical levers or gears especially the one pushing the paper forward... when you're done.. printing goes fine again...
Oct 25, 2007 | Epson Stylus Photo R320 InkJet Printer
Paper will not feed into printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Paper does not feed - GRABS RIGHT SIDE
I've had this error for the last 2 months and periodically tried to fix it. - I finally read a suggestion to try to push something thicker than a plain sheet of paper through. I cut a side of a manilla folder into a 8.5"x11" and let the printer try to grab it during a copy. After doing it's normal "grab the right side until it's skewed and stop", I continued to try to push it through. I wasn't able to push it to the printing area, but I saw that a piece of something (not much bigger than a bread crumb) came out of the feeder into the interior print area. - I tried another copy, and it was very slightly improved but still skewing and jamming the paper. Suggest unplugging it before performing this...I then lifted the interior piece of plastic (white color for my Pixma MP 150 - which would be located above the paper as it was fed into the print area) slightly to allow any jammed items to come through. Out comes small pieces and then a larger piece of cracker (about the size of 1/4 a cheez-it). Ok I feel dumb, but I'm glad I found something. I picked out the crumbs and did a careful vacuum in the interior and exterior paper feed. Slight warning: The foam bottom below the ink is not secured and will get sucked up by the hose. And note, that I did try vacuuming the intake and interior previously with no improvement. The nozzle on my vacuum is too large to get into the bottom of the exterior intake. - For good measure, I also picked up the printer and turned it upside down and shook vigorously in a couple angles. I saw a couple more small crumbs come out. - My printer is now feeding the paper correctly and successfully made a copy/print.
May 18, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
130 people viewed this question
old marine
old marine
