Question about Sharp Microwave Ovens
Need to Replace door on a sharp R1830 B how would I go about doing this?
  • 5,911 Answers
On MOST microwave ovens all you have to do is open the door all the way and lift straight up at the hinges. The door simply lifts all the hinge pins. You may have to remove the upper grill cover (if equipped) to accommodate.
NOTE: On some models there is a small hinge pin on the upper hinge that you need to remove first.
If you have questions, please let me know. I hope this helps you.
Posted on Oct 08, 2009
Testimonial: "Thanks much so simple I should have figured it out. thanks again"
Sharp carousel 1200 watts microwave manual
They is one of the DOOR SWITCH need to replace
Aug 17, 2014 | Sharp R-1480 Microwave Oven
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Trying to remove my Sharp R1830 microwave. We removed the top screws (into the shelf above) and the thumb screws at the bottom of the microwave that clip into the back wall bracket; but the clips seem to...
remove the bottom of micro and filters / with a light look up wher the filter 's are on both sides and you will find a lever that when your pull it .. it will relace from back plate. make sure someone is holding it at this time so it will not fall on range below . ****
Jan 09, 2010 | Sharp R-1480 Microwave Oven
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
Sharp microwave oven door won't close!
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
If needed, the best place to order Sharp parts is Tritronics.
Sep 14, 2008 | Sharp R-1750 Microwave Oven
Sharp R 1470A door panel
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
There may also be a piece on the side edge of the door which needs to come off, too.
You can probably find an exploded view by entering your model number here: http://www.searspartsdirect.com
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | Sharp R-510HW Microwave Oven
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Sharp Carousel Microwave R-1601 - Need to Replace Door
We have the service manual for the R1750-series ovens available at our Web site.
It's not exactly the same, but it should be generally close enough to help you.
It's at http://microwavedisplay.com/r1750_r1751_...
Most door panels separate like the one in the example photo below.
Please write back with more details if you need further help.
Dec 01, 2007 | Sharp R-1480 Microwave Oven
Microwave oven inoperative
When you enter the time then hit START, does the turntable motor come on? If not, then I would suspect the secondary interlock switch, its mount, or its wiring. If so, then it's hard to say, unless there was some miswiring somewhere. The original problem sounded like just a classic bad door switch. At this point I suspect the wires on one of them may not have been reconnected exactly where they were. It does matter. I would suspect the secondary interlock switch, which MAY have white/white and grey/grey wires attached. Also, one of the switch mounts may have a broken tab that makes the switch move so it's not getting activated. At our site, we have the service manual for the R1830, which is similar to the R1480-series. We have that plus *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 27, 2007 | Sharp R-1481B Microwave Oven
Microwave Ovens Logo
97 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
