Question about Sony PlayStation Portable (PSP) Console
Psp trouble my psp settings are correct but still won't connect to the internet what do i do next
    Problem Solver:
  • 9 Answers
Take your battery out wash it with warm water and then put it back in it happend to me before i did that and it was fixed
Posted on Dec 24, 2007
How to have internet connection on a PSP
Hi there. Here's how:
1. Go to the Main Menu of your PSP.
2. Go to Settings.
3. Scroll down to Network Settings and Press the X button.
4. Select Infrastructure Mode.
5. Select New Connection.
6. Name the connection so that you know it is for web browsing. (ex. WebConnect)
That way you can use another connection for the rest of your online games.
7. Push the Right Direction Key to go to the next menu.
8. Select the Scan option and let it pick up your WLAN settings.
9. Once it picks up a connect, Push the Right Direction Key to go to the next menu.
10. Select Custom for the Address Settings.
11. Push the Right Direction Key to go to the next menu.
12. Leave IP Address Setting on Automatic.
13. Push the Right Direction Key to go to the next menu.
14. Select Manual for your DNS Setting.
15. Push the Right Direction Key to go to the next menu.
16. Enter in 67.171.70.72 as your Primary DNS and just leave the Secondary DNS blank.
17. Push the Right Direction Key to go to the next menu.
18. Select "Do Not Use" for your Proxy Server settings.
19. Push the Right Direction Key to go to the next menu.
20. Push the Right Direction Key to go to the next menu.
21. Push the X button to save your settings.
22. Do a quick test of the connection to make sure it's working correctly.
23. Launch Wipeout Pure and go to the Download option in the main menu.
24. Select the name of the new connection you just made (ex. WebConnect), connect, and enjoy browsing the internet on your PSP.
Hope this helps.
Thank you for using Fixya!
Jun 30, 2011 | Sony PlayStation Portable (PSP) Console
My psp 3004 internet connection not supported what would i do
Hi yashb22,
Connecting to the internet using your psp is almost the same as connecting through your laptop. If you're having connectivity issue please try to check the error. One of the common error is WLAN switch is off, so make sure that it's properly toggled to the right. If you've already checked and still can't connect try doing the following steps below:
1. Make sure to turn on your PSP as well as the wireless/WLAN switch.
2. Then Navigate to " Network Setting".
3. Select "Infrastructure Mode".
4. Now Select "New Connection" and Name this connection.
5. Navigate to "WLAN Settings" Select "Scan".
6. Your router should now be listed.
7. Please go to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None".
8. But if you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA.
9. Then navigate to "Address Settings". Select "Easy".
10. Go to "Setting List". Verify that your settings are correct.
11. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X.
12. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
From this point you already established a connection.
Hope this information will be helpful.
Thank you for using FixYa.
Jan 16, 2011 | Sony PlayStation Portable (PSP) Slim...
How do you get internet on a PSP?
Hi ana01,
Connecting your PSP to the internet is just like connecting your computer to a router. First to consider is having an access point. So what is an access point? Access point is your router. If you wanted to get started going online using your PSP I suggest trying the following steps below:
1. Just turn on your PSP as well as your WLAN/wiresless.
2. Use the left and right directional button to find "Network Setting".
3. Now look for "Infrastracture Mode".
4. Please select "New Connection" and name it.
5. Go to "WLAN Settings" then select "Scan".
6. Your PSP will now detect your router.
7. Navigate to "WLAN security setting". Just leave the option "NONE", If you dont have an encryption in your Router set up.
8. But if have an encryption in your Router. Then put your WEP or WPA security key.
9. Go to "Address Settings". Select "Easy".
10. Navigate to "Setting List". Check if your setting is correct.
11. Go to the next page then save your setting by pressing x. Then press x again once you get a message that says "Save Completed. Test Connection".
12. Next message would say "connecting to access point." The next should say "obtaining IP address".
You already established a connection and you can now browse the net using your PSP.
Hope it helps.
Nov 15, 2010 | Sony PlayStation Portable (PSP) Slim...
HOW DO I GET WIRELESS INTERNET ON MY PSP
You need to find out your router name or SSID first. Check the network setting in your router.
1. Go to Network Settings under the PSP settings menu.
2. Select the "Infrastructure Mode" and press X.
3. Under "Select a connection to edit", choose "New Connection" and press X.
4. Now you will enter the connection name, press X.
5. Using the D-pad, name the connection "<whatever your router name is>" then select Enter and press X.
6. Now the connection is named "<your router name>". Select it and press >.
7. Under WLAN Settings, choose to "Enter Manually" and press >.
8. The SSID screen will come up next. Select the empty space underneath "SSID" and press X.
9. Using the D-pad, type in "<your router name>" then select Enter and press X.
10. Under WLAN Security Setting select "None" and press >.
11. Under Address Setting select "Custom" and press >.
12. Next, set the IP Address Setting to "Automatic" and press >.
13. The DNS Setting should also be set to "Automatic". After this is done press >.
14. Under Proxy Server, choose "Do Not Use" and press >.
15. Under Internet Browser, select "Start" so that the browser will be started after connection to the access point. Press >.
16. This screen will show your Settings List, press the > button after looking over the list.
17. You are now done setting up your connection, press the X button to save your settings.
Test Your Wireless Connection
18. Once your save has been completed, select "Test Connection" and press X.
19. Your PSP will now test your connection by connecting to the access point, obtaining an IP address and starting your internet browser.
20. If all settings are correct, you should see a screen confirming the connection.
Nov 02, 2009 | Sony PlayStation Portable (PSP) Console
How to get on internet with pspgo?
Go to Settings.
HOPE THIS WORKDS =P"Im a kid but Ill solve your question!"
Oct 05, 2009 | Sony PlayStation Portable (PSP) Console
LOST!!!
Go the left of the psp's menu (where you see the icons) and go to internet settings then add connection and it will search for internet connections then follow the steps.
Jan 21, 2009 | Sony PlayStation Portable (PSP) Console
AOSS
you need a wireless connection. And so after that, you go to the internet icon,and then you just type in your link.
2. Go to Settings.
22. Do a quick test of the connection to make sure it's working correctly. first you need to have a wireless internet at home. next you need to turn on the wlan on your psp, located at the left side corner of your psp. search for a wlan around you. if its not secured, your lucky, you can connect anytime, but if it has a wep key, you need to find out the key to be able to connect. Switch the wlan button (located on the left side) to on and if don't aoss router seperate from the psp you cannot use automatic. So goto new connection and press scan. Follow on screen instructions.
If you do have an aoss router press button on the aoss router inself so the psp can find it.
Okay now that ive given you your answer make sure to follow fixya's system. Instead of taking the answer and running.
THANK YOU,
NATE
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
I need help
you are doing it in the wrong menu. you are setting up a connection to location free player
2. Go to Settings.
I hope now that ive taken the time to answer your question. You will take the time to appropriately use Fixya's rating system since the question and rating system go hand in hand.
THANK YOU,
NATE
How to set up psp to internet
hey...there, try this one and follow the instuction.
2. Go to Settings.
Feb 13, 2008 | Sony PlayStation Portable (PSP) Console
Owners manual
Actually, there is an instructions manual ON the PSP! You need a wireless internet connection though... In the main menu on the PSP, there should be an icon that looks like a question mark that says on the side, "Online Instruction Manuals". (It's located under "Network".)
If you have a router in your house (Wireless internet connection) then you should be able to connect to it with your PSP.
Once you click on the icon, the PSP will say "You must create a network connection to continue." Press X to continue. Now it will give you a few options to get an internet connection. Before you go any further, make sure your WLAN switch is on. (It's located at the top to the left on the PSP.) next, click "Scan" at the top of the menu. The PSP will now scan for internet connections. It will give you a list of internet connections that it found. Yours should be in there. After clicking on your internet connection, it will say "SSID" and have your connection name displayed underneath it. Ignore this step and press right. Now it will say "WLAN Security Setting" and will have a list of security settings. If your internet does not have any security, press "None". It will now say "Address Settings". Press "Easy". Now you can name it. You don't have to, of course, but you can by clicking X to edit. It will show you your settings list. This is just to make sure that everything is correct. Press right to continue than press X to save settings. It will bring you back to the beginning with your internet connection name highlighted. Click on it and it will connect to your connection and load the page.
This online instructions manual is much better than the one that came with your PSP as it is kept up-to-date with the latest version of the PSP. If you have any questions, please ask! ^-^
Jan 04, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
