Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer looks like it comes on, door locks but drum does not turn any ideas?
    Genius:
  • Frigidaire Master
  • 1,474 Answers
If water is going in then could be motor or motor brushes/if no water check supply 1st then solonoid valves,,
Posted on Oct 08, 2009
Front end washer not washing or turning all u hear is the motor what causes this to happen
Hi Arthur Williams, this is AP! Thank you for your post.
I understand you are having trouble with your front load washer not spinning, but you can hear the motor. There are many situations that could prevent your drum from spinning. Overuse of detergent can result in too many suds restricting the tub from turning properly that will not spin out. Is the washer making a humming noise? Try putting the washer on spin only, if the drum will spin then it could be kinked hoses, if not it could possibly be the motor or the door lock assembly, timer, pump, control board not communicating. I would recommend having a technician come out to diagnose your front load washer. I hope this information proves helpful for you.
Thanks,
Mar 16, 2014 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire (ATF6000ES) Front Load Washer all lights come on and wont work.
Sounds like either the control board is faulty or the door latch sensor is not allowing the control board to communicate to the rest of the unit.
Aug 23, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire affinity front load washer that will not lock and start. I turn the dial, all pertinent lights come on, but no door lock and it alternates between cycle time and "Pau" which...
is there any water in the drum if no then it could be your door catch try shuting the door with a bit more force or pushing on the door when you turn on the machine if it does not start then it will be that you will have to replace your door catch
Oct 15, 2011 | Frigidaire Affinity ATF7000E Front Load...
Washer not working properly
The reed switch has been removed from the newer washers of same model. Nothing to do with the switch. Open door and turn the drum. This has happened to me a couple times. If the drum will not turn , try putting a little force on it. Mine acted the same and it was a sock that was stuck. Didn;t know what it was until I removed the boot where the coin trap is . and found a sock hanging down from the tub. stick your fingers up it the tub( with washer unplugged) and check for any material that might be there.
Jan 17, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
My cltf2940es0 fridgidare front loading washer will not start a cycle. The door will lock and the timer will set, however when the cycle should start the motor makes a subtle humming noise. This will...
unplug washer. take off bottom front panel remove rubber boot hose from bottom of tub to pump .have towel or cake pan ready for water.clean out boot and stick finger in pump clean out also remove drain hose at pump check for coin reinstall hoses this fixes must problems with front loaders
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Oct 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Door lock light on
The lid switch is defective, and you need to replace it.
Sep 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Sep 08, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
85 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
