Question about RCA RP5420 Clock Radio
My clock won't stop blinking and I can't set the time! How can I get it to stop blinking?
How do I change the time on a pampered chef clock/timer
Press CLOCK and HOLD until blinking light appears.
Press START/STOP to note a.m./p.m.
Press key "0" to move blinking dash over one place. if necessary, to set time.
Press # keys 0~9 to set actual time. Time will begin as soon as all numbers are entered. Example: Actual time is 4:35. Press # key "0" to move blinking dash into second position from left. Press 4,3,5,0,0. Press CLEAR in case of wrong key~in to stop process. Repeat procedure 1. To set military time, press 12 hr.~24hr. button on the backside of timer.
Nov 02, 2014 | Hardware & Accessories
HOW DO I ADJUST THE 1-4 HOUR AUTOMATIC SHUTOFF TIMER?
Press the ON/Off button until it time on the clock starts blinking. Then where the clock is just set the time to what ever time you like for instance 2 hours just set it for 2 and wait for it to stop blinking or just press the on/off button again for it to stop blinking. Hope this is helpful to you. Have a great day
Oct 23, 2012 | Cuisinart Brew Central 12-cup Coffee Maker
My clock is constantly blinking and won't go on the right time. I unplugged it and plugged it again, it just keeps blinking.
Hello
Check the bckup batteries in the clock first. If they are weak, backup function will not work properly, and the display will blink after a mains power failure.
Auto Clock Set
You do not have to set the clock time as a
built-in automatic time set system is
equipped in this clock powered by 3V (2
X AA batteries, included). All you have to
do is to plug this clock for power and
current time will be shown automatically.
However, the batteries can also be
exhausted and we recommend that you
replace the batteries every 2-3 years
Before You Plug for Power
1. Setting Time Zone
You may slide the TIME ZONE selector at
the back of the unit to Eastern (EST),
Central (CST), Mountain (MST) or Pacific
(PST) (refer to the maps on the right).
2. Daylight Saving
You can slide the DST switch at the back
of the unit to turn on/ off in areas
observing/ not observing such time
change.
WARNING: Please avoid playing with
these buttons after entering the
Clock/Alarm set mode.
Setting Clock
1. Slide the switch /WAKE1/WAKE2/
on the top of the unit to clock position.
2. Press REV or FWD to set the clock
time. The time decrements or increments
will follow by a faster rate when you press
and hold the buttons. The ":" between
hour and minute time flashes when you
are setting the time. AM or PM icon will
also beside the time.
3. Slide the switch /WAKE1/WAKE2/
on the top of the unit to position
when finished.
OK.
Aug 12, 2011 | RCA RP5430 Clock Radio
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
I just go the cannon mp27D and I am trying to set the time and date. I have followed the instructions very carefully but it still will not allow me to set either HELP Please
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
May 05, 2011 | Office Equipment & Supplies
I have an alpine raido CDE7870 how do I set the time
Setting Time
1 While the clock time is displayed, press and hold
the CLK (clock) button for at least 3 seconds.
The time indication will begin to blink.
2 Press the ZERO button while the time indication
is blinking to set seconds to "0".
3 Press the HOUR button to adjust the hours while
the time indication is blinking.
4 Press the MIN button to adjust the minutes while
The time indication will stop blinking 5 seconds
after the last adjustment. The time will
automatically be set.
Good Luck
Nov 14, 2010 | iLO XM-MP3-CD Car Stereo
How do you set the date and clock?
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
Setting the time:
displayed.
Jan 25, 2010 | Canon MP49D Calculator
SET THE DATE AND CLOCK
Setting the date:
Setting the time:
displayed.
Jan 25, 2010 | Office Equipment & Supplies
Emerson SmartSet Dual Alarm Clock Radio Won't Stop "Flickering"
Problem was solved. When clock was plugged in after a few more days, it finally stopped flickering and reported an incorrect time and day. Low battery was now blinking! Checked calendar and found all memory was lost. Purchased and installed a new battery and this time when clock was plugged in it correctly set itself! Fixed.
Sep 27, 2008 | Emerson Audio Players & Recorders
How do I set the time?
Setting Time
2 Press the CT button while the time indication is
3 Press the "H" button to adjust the hours while the
4 Press the "M" button to adjust the minutes while
Jul 28, 2008 | Alpine CDM-7861 CD Player
RCA RP5420 Clock Radio Logo
98 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
