Question about Apple AirPort Extreme Wireless-N Wireless Base Station
Can the wireless option on the airport extreme be turned off from the outside? I did not set a password.
    Novelist:
  • 177 Answers
Hi Friend
If you are using a Mac laptop then yes there is a way. on your MAC laptop there is a wireless switch to turn off and on the airport. You can use that to turn off the airport from outside.
warm regards
Chiranjeet Mitra
Posted on Oct 08, 2009
We just bought an Apple Airport Extreme router. After installing the Airport Utility software, and hooking up the router, we can not configure the base station using the Airport Utility. No matter what...
First time you should connect an Ethernet cable to the AirPort, and set it up with the software it came with. Then take a note of the wireless network's name (SSID) and the password (you might want to chance them to your personal preference though), security youre using (WEP, WPA, or WPA2)
Feb 20, 2011 | Apple AirPort Extreme Base Station
I need to change the channel settings on my RCA DCM425 cable modem. The problem is my company set up the router and wireless along with an ASA and I do not have any of the original information. How do I...
Cable Modem Troubleshooting RCA DCM425
or
You can change the radio channel on your AirPort Extreme using the AirPort Utility, as follows:
  • Run the AirPort Utility.
  • Select the AirPort Extreme, and then, select Edit.
  • Select the Wireless tab.
  • Select Wireless Options.
  • By default, the channels for both the 2.4 & 5 GHz radios are set to "Automatic." You would first change this to "Manual," and then, select the desired channel.
Oct 10, 2017 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
D_Rossetto@msn.comWhen I set up airport extreme I dont remember setting up a password when other people visit and try to connect to Airport Extreme it asks for a password how do I find out what that...
If you are sure that you didn't set the password, then the default password must be set with your Airport Extreme System. It depends on the model, some have none, some have; admin, tech, unknown, security, etc.. etc..
You can find all the lists of available passwords for Airport Extreme for deferent models. here: click here to open the direct link
If you need further assistance, you can refer to this Tutorials.. (click here).
Good luck
Thanks for using FixYa.
Aug 07, 2010 | Apple AirPort Extreme Router
I have a small home computer network that uses an Apple Airport Extreme as the wireless access point. My Sony Vaio (Windows XP) desktop is where I have my local area connection and was the first computer...
Hi there, you should reinstall the drivers for the wireless network adopter for your Sony computer. You need to go to the website of the wireless adopter manufacturer and choose your model of adopter and download and install the drivers for the wireless adopter.Please feel free to ask me any question about this problem.
Jul 14, 2010 | Computers & Internet
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Trying to connect acer netbook to wildblue internet using apple airport extreme. keeps reading "limited connectivity."
"limited connectivity" normally comes up when u type in wrong wireless network key. check the correct wireless password
Dec 27, 2009 | Apple AirPort Extreme Base Station...
Need to change my security PW to WPA from WPA2 which xbox360 does not support
Went into my router settings and changed the security password for my network to WPA only. This allowed my Xbox 360 to see my network.
Apr 11, 2009 | Computers & Internet
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
I tried to set up HP Photosmart C4580 printer/scanner/copier with my Airport Extreme. However it is not connecting to the Airport Extreme. Diagnostic check recommends temporariiy disabling the Mac Address...
MAC address filtering is used to prevent unauthorised people getting access to your wireless network. you need to get into the Airport Extreme configuration using Internet Explorer or any other browser, then select wireless setup then MAC address filtering. You need to turn off MAC address filtering.
Check your manual on how to configure your Airport Extreme.
Dec 02, 2008 | HP Office Equipment & Supplies
Wireless Modem don"t connect
well imac G4's don't  have built in airport (wireless internet) included as usual with apple its another item you must buy an airport extreme card  then hook it up to an airport base station another item to buy via wireless internet then hook you airport extreme base station up to your modem via ethernet. whew ok now sync the airport base station to your imac using airport set up application then select your network and type your WEP password and viol internet in about 1 hour if your lucky hope this helped my fingers hurt now LOL.
Apr 07, 2008 | Apple iMac G4 Desktop
Apple AirPort Extreme Wireless-N Wireless Base Station Logo
126 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
