Question about Toshiba Satellite A105 Notebook
I can turn computer on but screen is black - Toshiba Satellite A105 Notebook
    President:
  • 2,600 Answers
Try to hook the laptop up to an external monitor, that will point us in a general direction to help you see if it is a video output problem or a motherboard failure. If you can see a picture on an external moniter/tv, then you may have just lost the screen. If it doesn't produce a picture on either one, then you may have lost the video card and/or output on the motherboard.
Posted on Oct 08, 2009
When i turn my computer on the screen is black for awile then it comes on where i can see my screen saver why does it do this
Turn the computer off.
Turn the computer on,
and keep pressing the 'F8' key until you see a "start-up" menu.
Choose "Start in Safe Mode".
Does the screen now look normal?
If so, set the "screen-resolution" to 800-by-600.
Then shutdown and restart.
Feb 09, 2015 | Dell Computers & Internet
What would cause computer not to turn on when the power is loaded and the screen to stay black?
Im sorry about your situation.
Does the computer turn on??
If the computer turns on do you hear or can you see the fan working??
If the computer turns on does it stay on or does it shut down after a few minutes??
This will help us determine what is going on.
May 31, 2014 | Acer Computers & Internet
Turns on but black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Oct 04, 2013 | MSI Wind U100-030US Laptop
My screen is black
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Jan 20, 2013 | HP Compaq Presario CQ50-210US Notebook
Black Screen!
perform power drain. take out the battery and unplug the power adapter. press and hold the power button for 30 secs. put the battery back in and plug in the power adapter then turn on the computer.
May 03, 2010 | Computers & Internet
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
My screen randomly blacks out.
the best method to overcome this problem is format the computer!!! i too used to get the same problem!!i did format it...!
Dec 30, 2008 | Microsoft Windows XP Professional
Monitor turning black
the backlight fluorescent bulb is burned out.
Dec 26, 2008 | Computers & Internet
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Toshiba Satellite A105 Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
