Question about Sony Cyber-Shot DSC-W1 Digital Camera
Cant go to picture mode, error on screen shows turn power off and on. and while doing so nothing happens
    Problem Solver:
  • 10 Answers
It's timeto bring your unit to sony service
Posted on Oct 08, 2009
I have forgotten my pin code for my supersonic SC-74MID tablet. How do I reset it?
I don't know which OS your tablet uses... perhaps Jelly Bean. If so, if you push the Power button and the "Power Off" option shows up on the screen press the selection of "Power Off" and hold your finger down on it until a pop-up screen shows a selection of: Boot into "Safe Mode". Choose that and what happens is it boots up with no applications loaded. You should then be able to access the "Settings" and then choose "Factory Data Reset" option. Hope this works
Jan 08, 2013 | Supersonic 7" Touch Screen MID Tablet
When i turn on the pc it the moniter screen is black and the screen says press any key on board or mouse. in power save mode. i did this but nothing happened. how can i fix the problem?
Try changing your power settings.
Go under your Control Panel. Then access your Power Options. Edit when to turn off computers display.
This should get your power save mode to prevent any errors/bugs.
Mar 15, 2011 | Dell Computers & Internet
My Cyber Shot DSC W55 when i open it the lens keeps moving forward and backward and then something shows on the screen which says First "ACCESS" then the next one is "Turn The power off and...
Error: TURN THE POWER OFF AND ON AGAIN or Access is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Feb 24, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Wont do nothin
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 06, 2010 | SanDisk Sansa e260 MP3 Player
As soon as I power on My Dell D610 in boot screen appear : '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for...
''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for shutdown, nothing happening with that operation either.
Jan 19, 2010 | Dell Latitude D610 Notebook
Cant go to picture mode, error on screen shoes
try to remove the battery first for a few minutes...then retry. This might help reset the system
Aug 10, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
No view on screen of what is showing in front of lens. Menu and playback shows but nothing when i turn to camera mode or video mode.help!
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
May 05, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
USB Not working =S
Possibly, the cam is in webcam mode or other mode beside camera mode. I have an older sony and there is a mode that doesnt seem to work for me too. Im not next to it so I cant tell you what it is, but look into the setup screen and make sure the camera is in USB mode.
Mar 04, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
No images/picture:only right after turn on
Could be A. Battery contacts need a clean take them out and with the end of pencil eraser clean the contact in base of the chamber. B battery door losing tension - press it closed whilst in use. C. an internal connector worked loose try gently squeezing around the base of the screen- this usually where the connectors are. Do get onto Canon Tech Support Team. Just be prepared for a no repair solution. I.E. new camera
Jun 30, 2007 | Canon PowerShot SD10 / IXUS I Digital...
Sony Cyber-Shot DSC-W1 Digital Camera Logo
101 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
