Y connector on EXHD necessary?
My external hard drive (500gb) usb powered. has 2 usb connections,(Y splitter cord) do i need both of them plugged in? it seems to work with only one. is this bad for it? What is the function of having 2?
    Scholar:
  • 131 Answers
You only need one. :)
Posted on Oct 09, 2009
How to connect
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall....
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Transcend StoreJet 500GB cannot be opened
Several things could be happening here:
1. your electronic controller in the hard case has failed.
2. you didn't properly disconnect the external hard drive in Windows > with the
"Safely Remove Hard ware and eject Media" in the task bar.
3. if you have a power supply to the USB drive it may have a damaged power connector or not supply proper power to the device.
Mar 16, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
My hard external hard drive is not detected by any pc I plug it into it powers up (gives noises and light) but it's not being detected please help thanks
Try using a different usb cord. If the device is still not working properly after that there may be an issue with the circuit board that attaches to the drive in the enclosure. If this may be the case you can purchase an new enclosure for the drive that comes with a new board for a reasonable cost. If you have a ide or sata to usb connector you may be be able to remove the hard drive from its enclosure and retrieve any data you may have stored on it. Here is a video I located on the web on retrieving your data. A few steps are unecessary if you have to ide to usb connector you will not need to disassemble your pc.
http://www.metacafe.com/watch/1000351/recover_data_from_external_hard_drive/
Mar 08, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
How can I power up my seagate 7200.11 500gb external h/drive to my pc
If your OS supports this device ... plug in the power supply to proper voltage ... and connect the end to the device. Use a appropriate USB cable from the back of the Seagate and plug into an available USB connection on your computer.
Oct 03, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Do I need only one cord (usb) to connect to my laptop?
The "physically-smaller" external hard-drives draw power through the USB cable.
The "physically-larger" external hard-drives require an external power-supply (just like a laptop requires an external power-supply).
Check the casing for a plug where the electrical power would come in; if none, then the unit will draw electrical power through the USB cable.
May 31, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Usb port on free agent 500gb external hard drive is inside case can not plug usb cord in ??? fix case be taken apart to get usb connector out
Sounds like you will have to take the case out to see if the connector if even fixable. The good news is that a new USB drive enclosure is not all that expansive even if you need to buy a whole new case.
Oct 09, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Lost FreeAgent Pro power cord...where do I get
You can pick up a replacement cord at radio shack. they have universal cords that match the power rating.
Sep 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
500gb St ex hard drive suddenly disconnects when still plugged in
please try to check your external hard drive if theres a problem aside on the cord connecting to pc...
Jun 16, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
I recently purchased an external hard drive, and how do connect it to my computer.
External Hard Drive is mostly of the USB interfacing type. If urs one is the same, then it is just as simple as plugging in a pen drive in the USB port. If it has external power supplies then u can easily figure out how to connect. There are two parts in the power supply (if external power supply cable is provided), 3-pin main power supply connector and other is the adapter which goes to the external hard drive.plug in the other end of the adapter into the hard drive (there is a hole in it). connect the main power cable to the adapter extension. now for the usb Hard Drive, connect the USB cable to the USB port of the computer. Switch on the power supply to the Hard drive and u r ready to use ur brand new External Hard Drive. If it is a Firewire interfacing one then u may need to open the CPU box, and then connect the firewire connector on to the motherboard firewire port. It is easy to identify, it is a red colored port/connector.
Oct 11, 2008 | Western Digital 500GB My Book World...
Computers & Internet Logo
David Payne
David Payne
