Question about Briggs & Stratton 08-Gallon Wheelbarrow Air Compressor - 074002
Hello, my 8 gal briggs &stratton wheelbarrow air compressor will run to 145 psi then just stall out, if i trip the unloadrer valve before it dies then it just goes full speed and sounds like its goin to blow up, whats wrong with her?
  • 3 Answers
Your unloader valve isn't unloading. This valve is supposed to stop the compressor at (likely) around 125#. If it's one that you can service, try adjusting it back down to 125# - if not serviceable, it'll have to be replaced. Make sure that your pressure line between the valve/tank/governor is intact and not kinked, too.
I'd like to know how this one turns out, please!
Posted on Oct 08, 2009
When max pressure reached engine dies instead of idle down
Has Pressure Switch Issues - About Air Compressors
www.about-air-compressors.com/has-pressure-switch-issues.html
Many times folks think that they have a pressure switch problem since air leaks out the ... The pressure switch does not kick off when the compressor has reached itsmaximum pressure. ... compressor sits humming and trying to turn the motor insteadof cutting out. It is a ... I have an old, about 20 year old, Ingersoll-rand T21.Missing: idle
[PDF]21 Front St. - Celtic Distributors Ltd
www.celticdistributors.com/content/Celtic/.../BasicCompressorTraining.p...
The air compressor motor and/or engine will get hot while in operation. .... enters thru the intake ?lter and the intake valve on the down stroke of the piston. .... My gas unit builds pressure but instead of idling the engine dies? 0 Check ... most single stage compressors only reach maximum pressure of 125 to 135 PSI. A slight.
[PDF]ALTRONIC GAS ENGINE GOVERNOR OPERATING ...
www.altronicinc.com/pdf/engine-controls/govinstall.pdf
Dec 16, 2015 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Central pnematic compressors, will not build up air
Use soapy water to check for air leaks. Can also check piston ring and valves. Make sure engine is driving the compressor.
May 19, 2013 | central pneumatic 212cc, 9 gal., 135 PSI...
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
I have a C2150 4 gal compressor from Porter cable with 2hp peak and 1.2hp continous rated motor. The problem is that I can not run the compressor on a 15amp circuit with out tripping the breaker. It even...
Try to use a higher amperage extension cord.
This unit is rated for 15 amps. It should be able to run on a 20 amp circuit unless there is voltage drop due to small wiring. Try an air conditioner extension and let us know the result.
Gary
Dec 19, 2010 | Porter Cable C2002 150 Psi 6 Gal...
After 100psi the compressor stops. It apprears to be dragging before then as well. I am using I.R. all season oil as recommended. It has less than 50 hours on unit. I have changed the oil 3 times in those...
possibly the check valve but most compressors shut off at 100 psi
it could be that the motor is not of sufficient capacity to go to a higher pressure and that is why it appears to be struggling
Feb 22, 2018 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
What is the torque for head bolts on my ingersoll rand ss3 compressor?
I can't say from their manual, but I've never rebuilt a compressor (and I check every one with the mfg) for which the head bolt torque isn't in the range of 25 ft. lbs. to 40 ft lbs. If you can't find it, torque to 30 or 35 and you've got it knocked.
Nov 25, 2009 | Ingersoll Rand SS3J5.5GB Wb Ir Portable...
I went to start my go kart 5 hp 135212 model and when i did it trying running full thottle on its own i had to hurry up and turn it off fool with the throttle and the clutch but still the same.
check the throttle position and make sure that its not stuck in the open position if its ok check the internal components of the carburator inside the flapper may have fell off , its usual held in place with a screw or 2. check the govenor and all springs
Jul 08, 2009 | Ingersoll Rand SS3J5.5GB Wb Ir Portable...
Blows the relief valve
If you have the manual, check the compressor and normal pressure settings and ratings - 145 psi sounds high and unless you are using huge air tools. You may not need that kind of pressure. It sounds like the relief valve and motor overload are both doing their jobs to protect the system.
Mar 17, 2009 | Air Tools & Compressors
Briggs & Stratton 08-Gallon  Wheelbarrow Air Compressor - 074002 Logo
197 people viewed this question
Top Briggs & Stratton Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Air Tool and Compressor Expert? Answer questions, earn points and help others
