Question about Acer Aspire 5100 Notebook
Keyboard loads in Bios...
When BIOS loads, keyboard works. Between BIOS completion and XP completely loading, the mouse and keyboard do not work.
I need to do a full hard drive wipe to clean up desktop to give away. Any thoughts?
    Habit-Forming:
  • 115 Answers
Reload the driver once in windows. unload key board drivers. and let it seek the key board and mouse again.
Posted on Oct 09, 2009
Need to download dell sata drivers to install windows xp
Do you the install disc.put it your cdwriter.let windows start from it and loading files.choose then to repair the computer.if that do not work but it should.try CMD in safe mode.as Admistrator write. SFC /SCANNOW it will tell you if it is any corrupt files as you think good luck mike.
Apr 02, 2013 | Dell Dimension 3100 PC Desktop
I have a xp pro system. The keyboard and mouse work during BIOS. They will not work in safe mode or in windows. I have tried other keyboards and mice. None of them work. I am running eyeonet dvr software....
somewhere in the bios you might have a setting for lecgacy or usb 1 or usb 2. just select a different option and try again. this sounds like a common problem but only the other way around. usually if the usb setting is wrong a keyboard doesnt work in bios but works in windows.
Sep 15, 2010 | Dell Computers & Internet
No usb keyboard and usb mouse
You need to ensure that the chipset drivers are loaded.
Mar 10, 2010 | ASUS Computers & Internet
Gateway 2005, windows xp, pentuim 4.trying to fix my girlfriends computer. We are in the process of instaling a geforce video card. I installed the video driver on on her harddrive with my pc. After in put...
is it a usb keyboard? If so it must be enabled in BIOS. Also if enabled OK, then when at desktop next,, unplug and re-plug into another usb socket and it should be detected and a driver will install, thaat may fix it?
Feb 18, 2010 | Computers & Internet
Keyboard/floppy diskette error
try to unplug the power chord from the tower, press and hold the power button for 10 seconds. now try to turn the system on. still if u have the keyboard error try to reset the keyboard . still if have the same error get into the bios and load the bios default. For the floppy diskette drive seek failure, u have to get into the bios to disable the floppy diskette drive.
Jun 11, 2009 | Dell Dimension 4600 PC Desktop
Wireless mouse and keyboard issues
If you have both sets of keyboard and mouse plugged in, turn off the computer and remove the old mouse and plug in the new mouse. Reboot and if necessary use the keyboard to login. Once windows is loaded let it detect the new mouse and then shut down again. Take out the old keyboard and reboot. You should now be able to use both new pieces without problems.
Jun 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
KB Genuis Luxemate 320 USB can not choice OS in loader's menu.
Try to change in the BIOS the option "Keyboard USB" from value "OS" to "BIOS".
Mar 18, 2009 | Abit NF7-S V2 Motherboard
Dell Latitude D800- Keyboard and mouse stop working when undocked.
First update any drivers for your dell.
www.support.dell.com
Is the dock a dell dock, or a universal Dock?
the drivers may need updating.
Some times when you plug a dock in, and turn it on, they will load them into the drivers and when you unplug it, it gets confused and when you boot it up it has to re-install the original drivers and does this while its booting.
This happens alot with the GX620 desktops. If you pull a USB keyboard out while its off and plug it back into a different USB port and tun it on. It wont work right away.
We end up having to let it sit at the login screen for a while till it reloads the drivers to the new USB port.
You will know if yours is doing this as the Hard drive light will be flickering and running.
Try booting it up and letting it load windows and waiting a few minutes.
Sep 20, 2008 | Dell Latitude D800 Notebook
Bios does not find PS2 keyboard/mouse
Did you go into the BIOS and set it to recognize the USB Keyboard after you reset the BIOS? Is windows not noticing it or the BIOS. You stated that it recognized the USB keyboard and then said that it did not.
What does all of this mean? USB keyboard does not activate "del" setup.
If it does not work, it is because you reset the BIOS and did not change the settings back for the USB keyboard.
I hope that I fixed your problem.
Jun 04, 2008 | AOpen AX4BS (91.32Q10.002) Motherboard
Can't load os do you computer Dell only has usb ports
Ensure the Keyboard and mouse are connected to the USB ports nearest the PS2 port on the back of the chassis.
Boot to the BIOS F2 and ensure USB emulation is ON.
If you can't access the bios, reset the BIOS using the Jumper on the motherboard, then USB ports should then work.
May 18, 2008 | Dell OptiPlex GX280 PC Desktop
Acer Aspire 5100 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
