Question about Juki TL-98Q
When iremoved it, a thin metal piece came out and i don't know where it goes exactly
    Problem Solver:
  • 15 Answers
Take the machine to a sewing machine repair shop.
Posted on May 29, 2010
The spring in the bobbin case in my Janome 1600P came out when I took the bobbin out - how does it go back in?
This thin piece of metal is likely damaged. a new case is only around $5.00
Same as this one
Sep 21, 2014 | Sewing Machines
I have a Brother SE2700 and a piece came off that helps thread my needle, its a metal piece that goes right under neath where the needle cartiage goes in to thread my needle, I have the piece but cannot...
Unfortunately, the part may very well be broken. Unless you can find someone to repair it for you, you may have to manually thread the needle. Not such a big deal, really. Auto needle threaders have been around for only about 10 years, so machines were manually threaded for over 100 years.
Something that helps:
Lick your index finger
Swipe it across the "back" of the needle eye
(the moisture in the eye will almost cause the thread to jump through it!)
Jun 06, 2017 | Brother SE-270D Computerized Sewing...
Where do I oil my 1017 machine
Take apart the machine. Remove the screws; just remember where you took them out of. All of the pieces are just covers to cover the moving mechanisms.
Wherever metal rubs on metal, oil it. There is often a hole in a metal piece that goes around another piece. Put a small drop of oil in the hole. There are usually lots of holes in lots of metal pieces, meant for oil.
May 26, 2011 | Janome Harmony 1017 Sewing Machine
I inherited an Elna 2002 and I can't figure out where the spool of thread goes on the machine. There are two round metal pieces surrounded by a piece of felt on the right side of the machine but nothing...
Can you pull the metal pin up, I know that the Elna 5000, 7000 and 9000 all had retractable thread spool holders. There might be a little lip on the edge of the metal pin that you can grasp with your nails to extract it upwards.
Apr 27, 2011 | Elna 2007 Mechanical Sewing Machine
MY BOBBIN CASE FELL OUT TWO PIECES HOW DO I PUT IT BACK TOGETHER
I assume you actually mean the metal ring that holds the small round case that the bobbin itself sits in. There are usually two arms that swing in to hold that larger metal ring in place and then there is a plastic and metal piece that sit behind the large metal ring. fit the plastic piece that may look somewhat like a scoop next to the metal piece that usually has the post the the bobbin fits onto and has a quite sharp tooth on it. The metal ring then goes on to hold those two pieces in place and the two arms swing in to hold the metal ring into place. The bobbin or bobbin case now can be put back in. Hint on metal ring placement: they almost always have a notch that goes at the very top where the arm on the bobbin case sits in when it is in place. You may find it easiest to do this with the machine laying on its back so you don't have to have 4 hands to hold everything in place while putting everything back in.
Feb 22, 2011 | New Home HF-2022
On a brother cs 8060 - as i pushed the thread compartment into the machine a silver metal forked thing flew off the machne hitting me in the neck. it has two pins one on each side and is actioned by a...
the piece that flew out goes to the piece that lowers with the wire. mine is having same issue but i saw mine right before it flew off. not quite sure how it goes back together.
Jan 07, 2011 | Brother CS-8060 Computerized Sewing...
Singer 2932 automatic threader
A new part is faster and easier but sometimes the problem is a bent hook( the tiny part which goes through the eye of the needle). Remove the needle to see the part better and pull the threader down. Look in the very center of the threader for the hook. It is probably pushed to the right.Using a small screwdriver or other thin piece of metal, force the hook back to the center. Try it and continue until it enters the eye again. By the way, a Singer dealer can get this part for you for under $10.
sewman7
Aug 09, 2008 | Singer Sewing Machines
Parts fell out
WE FIXED IT!!!!! Ok my fabulous husband fixed my automatic thread foot last night and now I am sewing away. Here is what he did best I can describe. when you engage the thread shuttle, a piece comes down from the right of the sewing machine. I has a spring on the back and a very thin piece of wire with a white plastic moving part. the foot has to snap under the white plastic thing... so you have to very carefully take the white thing out of the track and then put the foot in. the bar side with the larger metal pin goes here and the foot should be facing towards the needle. Hope this helps and if I didn;t explain it well please leave me a note and I will try again :)
Apr 18, 2008 | Brother SE-270D Computerized Sewing...
Bobbin thread getting caught
Check your Instruction manual - if you have taken the bobbin case apart to clean it, the shuttle must be reinserted with the little tab pressing against the piece you mention. It is under page 45 - "Caring for your machine" in my book. I missed it the first time I cleaned and oild mine.
Mar 21, 2008 | Singer 3962 Mechanical Sewing Machine
My needle broke and a piece of metal fell out of machine
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Juki TL-98Q Logo
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
