Question about Garden
Old old lawn tractor It starts but does not
Old old White lawn tractor It starts but does not continue to run I removed the air filter and noticed a significant amount of gas coming out of one of a holes seeping back to the intake (I think its the intake) and eventually flooding out. I noticed that when I covered the hole with considerable pressure with my finger it continued to run. A pretty good amount of pressure built up from that first hole. upon removing my finger the engine floods and stalls out.
While running with my finger on the hole it has white smoke from the muffler. but does run. What does the white smoke indicate and how to I get the thing to run steadily. Oil just changed
    Sergeant:
    Champion:
  • 257 Answers
NOT A EXPERT JUST TRYING TO HELP,,,SOUNDS LIKE YOU NEED TO CLEAN CARB. OR REBUILD IT,,, HOPE THIS HELP
Posted on Oct 08, 2009
How do i stop the back firing and get it started
I had possibly the same problem with my lawn tractor about a month ago... I tried removing the carburetor and cleaning it, but I always ended up pushing debris into another area and creating new problems. Eventually I just bought a new carburetor, changed the oil (some gas had gotten into my oil thanks to the problems I had with my carburetor), cleaned the spark plug, emptied the oil filter and replaced it, checked the air filter ((no oil there, phew)... and it seems to be running fine after 3 engine hours (knock on wood).
My backstory is the lawn tractor was sitting in the garage with our car for two years and not used. I prepped it for long term storage, but failed to drain the carburetor of old gas, so the old gas gummed up the works (even with fuel stabilizer). When I did get it running (after changing everything listed above) a lot of smelly white smoke kept coming out, but as I let it idle in fast speed the engine strokes became more regular and the bouts of white smoke became fewer and shorter until the smoke stopped altogether.
Hopefully this helps!
Aug 10, 2014 | Craftsman Garden
My 12 year Craftsman lawn tractor with 20.5 hp B/S engine and 42" blades will not start. The starter turns over fine but no start. I don't know if it is igntion or fuel problem. I replace the...
Test for spark. Make sure the air filter is clean. Then make sure fuel is getting from the gas tank to the carb. Old rubber fuel line deteriorate and stop up small ports and parts in the carb. An inline fuel filter is a good idea on these larger engines. Sometimes, a larger B & S engine needs the OH valves adjusted to start easily and run properly. If after attempting to start, does the new plug get wet or even smell like gas? You should always use gas LESS than 30 day old. Gas goes stale like bread and milk. You can remove the fuel line from the fuel tank at the carb to drain old gas. You can also remove the carburetor bowl to check for water and sediment (which need to be cleaned out). Check these things and post back.
Sep 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Craftsman 15 HP Lawn tractor is spewing white smoke. When I removed the air filter, I noticed there was oil all over the inside of the air filter and at the bottom of the air filter. When I run the...
I could be caused by a couple things, the most common is overfilling with oil, running on too great of angle and flooding the valve stem area or really bad valve stem seals.
Jun 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have CraftsmanLT1000 lawn tractor, Smokes heavily.
Many times a dirty air filter will cause this on this style of engine. When the filter is plugged, it creates a 'rich' fuel condition, and the engine smokes heavily, the excess carbon is drawn into the air filter, and plugs it even more.
check spark plugs, air filter, fuel filter, choke linkages (for full choke/no choke operation) and crankcase oil.
Crankcase oil can become fuel contaminated, thus overfilling the crankcase and filling the crankcase breather with raw oil/fuel, and this is drawn into the air filter, plugging it, and starting this senerio.
If there is fuel in the crankcase oil, drain completely, and refill with fresh oil. Then you need to look towards the carb for an inlet needle sticking, broken, worn.
Nov 15, 2009 | Craftsman Garden
10 year old Craftsman Lawn Tractor won't start
That's really strange. The low-speed fuel adjustment screw may be set way too rich, but that doesn't seem likely. With the air filter off, look at the choke plate if possible as you advance the throttle and see at what point the choke closes. Back it off till the choke opens and then put the filter back on and try to start it at that setting. Another thing that could cause too much fuel is if the adjustment of the carburetor float is off, causing the fuel level to be too high in the carb bowl.
Aug 03, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Tractor starts then stop running
It will either be the stator that needs changing or the carb needs to be pulled off and cleaned
Jul 01, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
May 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
6yr old Craftsman Lawn Tractor - Koehler 18 HP Auto. Sputter&Dies
Try running it again and when it starts to die remove the gas cap and see if it starts to run better. It's possible that the gas tank isn't venting correctly. If that doesn't work post back and we'll try to come up with some other solutions.
Apr 22, 2009 | Craftsman Garden
Garden Logo
152 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
