Question about Home
Grout in bathroom & shower is cracking, probably due to movement. What is best way to remedy this? Silicone caulking?
  • 302 Answers
If it were me,I would replace the grout,but that's my job.lol
Silicone caulking will just leave an ugly mess if it's cracking in random (large)areas,however,it would keep the water out.
If you have lots of ambition you could try to patch with grout. You would need to purchase the same color of course. Mix up small batches at a time and use your finger tip to spread the new grout into the bad spots or use a small putty knife for spreading it. I wouldn't spend the money on professional tools unless you plan on doing this full time.
Even a piece of cardboard could be used to spread it.
Follow the directions on the grout package,just using smaller amounts. Apply grout,let sit for about 10 minutes,and then wipe up excess with a damp sponge. Make sure you only make one pass at a time and do it gently...rinse sponge between wipes.
Posted on Oct 14, 2009
How to Grout ceramic tile to shower base
Don't use grout! Instead use silicone caulk that matches your grout color as close as possible. Never grout where tile meets at a 90 degree angle it will crack.
Jul 13, 2014 | Building Materials
How do i seal a crack in the grout on the shower floor using wet area silicone? Is this suitable and what do we do?
problem usually happens when grout is not fully cured and sealed when water penetrates it so... remove old grout using grout removal tool (you can pick up from any where that sells flooring(tile) pick up some new sanded grout to match and sealer apply then seal 24 hrs cure time is req. before sealer wait 2 hrs then re-apply sealer 7_2_2014_6_45_58_am.jpg
Aug 31, 2013 | Home
I had a shower total replacement less than two years ago. Company out of business now. Shower grout has cracked bad at base and in corner all the way down. I need to re-grout. Problem is the gap in corner...
Use a good quality bath and tub caulk applied to the deeper parts of the gap. Do not fill all the way out to the top of the gap with the caulk. When the caulk is dry, then apply the same color grout over the caulk.
Jan 21, 2013 | Home
I had a shower total replacement less than two years ago. Company out of business now. Shower grout has cracked bad at base and in corner all the way down. I need to re-grout. Problem is the gap in...
Try using a small amount of thin set, Troll it in and be sure to leave a small gap. Let it dry and then use a high quality silicon caulk. Be sure to let that dry for at least 48 hours.
Good luck,
Marty
Jan 21, 2013 | Whirlpool Water Heaters
Where does the rubber membrane go when tiling a bathroom floor
tiles on wooden floors will always move and crack the grout/tiling cement
therefore the rubber membrane goes down first with out nails and then everything is laid on top
that way when the wooden floor moves , there is a water proof membrane to prevent the water from rotting the wood over time
Jun 14, 2017 | Home
Need to remove silicone from 4 part shower stall to repair & reinstall
I think you should contact to a professional who can remove this shower stall very easily without any risk. You can also have a look at shower enclosures for having such bathroom stuffs in affordable price.
Jul 14, 2012 | Home
I'm insytalling new tile in shower should the frame of the shower doors be caulked?
Hello. Definitely yes. You want the tile, grout and caulk to be a semipermanent barrier for the water. If you do not caulk the frame, water will get in there and either leak or cause mold to form. Use a good quality silicon caulk, either clear, or white or a color that matches your grout lines. J.
Jul 28, 2010 | Home
Walk-in shower floor problem
They probably use wrong adhesive that is not hard yet and have tenedency under pressure to squeze out between grout lines. Yes they need to address the problem immediately.
Jan 14, 2010 | Home
I have frameless shower doors, the bottom sill is tile, with grout lines. Water leaks under the shower door through the grout lines, how to correct this.
if the glass actually contacts the tile you can go to the homedepot or similar place and buy some glass silicone sealer and just run a nice bead of caulk along the line, make sure you get clear silicone and let it thooroughly dry before you get it wet
Sep 14, 2009 | Dmm Vigo Frameless Shower Enclosure with...
Leak in the shower is leaking water through the ceiling
Hi lorenzotwalk,
I'm Harvey the Master Plumber.
Your problem is: When you use the shower, water leaks through the ceiling.
First, since it only leaks when you're using it you can ignore the water lines. Now comes the detective work. Look very closely at any place the water can squeeze thru, i.e. cracks in grout or caulk, etc. Don't forget to look on the floor imediately outside the shower and around the shower door if any. If found it must be scraped out, cleaned and dryed to get good adhesion, then caulked with a high quality silicone caulk (color of your choise). Any other caulk will crack no mater what they say.
Let dry for 24 hrs.
If you havent found this kind of problem it's time to look at the drain line connection. You may have to open the ceiling to do this, that's why I'm always carefull in the first step. Turn the water on and watch the drain connection. If it leaks there, it must be repaired. In this case you might cunsider checking the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 18, 2008 | Home
Home Logo
215 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
