Question about GoVideo DVR4000 DVD Player/VCR
Go Video DVR4000 - DVD loading mechanism unresponsive
Machine seems to work normally from front panel, though sometimes it
won't change control back to DVD module without powering off first. If
loading gear is turned manually, then DVD plays. Load/unload shows up
on LCD panel, but nothing happens.
Checking voltage at loading motor was unclear; when load command was
read, digital voltmeter fluctuated, but never read significant voltage, nor
stabilized on any particular DC voltage. Micro switches nearby respond,
but exact sequence of function unclear and so untested.
Is problem more likely to be the loading/unloading motor, or the controller chip?
Thanks for any insights.
SOURCE: unable to unload pictures from camera to computer
I've never used a "program" to download my photos, and I've been able to download them on any computer whatsoever. Plug the mini-B into the camera, then plug the USB into your desktop while it is off. Turn the camera on with the switch in View mode. Turn your computer on. Go to Windows explorer or My Computer. Your camera should show up as if it were a data drive with an icon of a camera. Double click that icon and you can view photos at will. Right click any photo to save, or use pull down menus above to save multiple photos at once to other drives.
Posted on Dec 14, 2007
SOURCE: DVD + VCR Combo DVR4000 Go Video
My suggestion was I took it to a TV repair shop. They have not called me about what they found out yet.
Posted on Feb 21, 2008
SOURCE: "Bad Disk" message
I determined the equipment was shot and bought a new one. Much less stressful and rather pleasant!
Posted on Apr 26, 2008
  • 131 Answers
Posted on Nov 08, 2008
  • 3 Answers
Are you inserting homemade burnt dvd's ???
Posted on Nov 18, 2008
Blinking red light on panel keeps ejecting tape
There seems to be problem with the ejecting mechanism of your device. It is not properly closing. Try opening the device and clean the ejecting mechanism and load tray. If the problem persists, get repaired at the authorized service center.
Nov 11, 2013 | GoVideo DVR4000 DVD Player/VCR
Disk won't eject
Normally all readers have a mechanical system that can be accessed from the front or the back of the reader to open using a small tool. Normally it's a little hole (like on smartphones) where you can insert a metal piece and push on it to eject the drawer.
May 30, 2017 | LG RHT599H 500GB HDD DVD Recorder with...
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Were to get a pdf manual for the go video dvr4000
Click HERE to download user manual pdf file for DVR4000
Oct 18, 2009 | GoVideo Go Video DVD/VCR Combo
Need a new remote for a DVR4000. Can you help me?
Salutations pe99er,
Your best bet maybe through an auction site or a third party parts site. You should be able to find sites to get the parts from by entering "DVR4000 Remote" in a search engine.
Happy hunting.
Go Ahead. Use Us.
Jun 05, 2008 | Televison & Video
Video freezes
my dvd player does this (its a diff make n model from ur's ) i've found its the discs that it doesnt like, i had to go thru many diff brands of disc b4 i found 1's it will play without problems, hope this helps
Jan 27, 2008 | GoVideo DVR4000 DVD Player/VCR
HE3 washer Control malfunction?
Bad control board is most likely problem.
Dec 09, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Will not start
sounds to me like the main computer is malfunctioniong could also be the touchpad but that is less likely.
Sep 29, 2007 | Maytag Neptune MAH5500B Front Load Washer
Front panel controls are unresponsive
Check volume up switch in front panel locked continuously. If it is not take away the remote control from the TV or remove the battery in the remote. Because maybe the remote continuously sending volume up commands. Rarely this type problem occurs through remote control also. Even problem is not sorted there is problem in EEPROM ic (memory ic). This can be sorted out by the technical persons only. I hope this useful to you.
Aug 31, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
GoVideo DVR4000 DVD Player/VCR Logo
91 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
