Question about Toshiba W522 VHS VCR
Program button goes to fuzz channel, no regular channels show up
My VCR, Toshiba W522CG, was working fine. Then a button was pressed on the remote (I don't know what button, but i suspect the l.select). Since then, when I try to access the set up or programming through the "Prog" button, it goes to fuzz and a flickering messed up channel. No TV channels will show up through the VCR now. I don't know how to get it back; I've unplugged the VCR and plugged it back in--nothing fixes it.
I would so appreciate any help.
  • raindew01 Dec 24, 2007
    I just solved my own problem--something simple. It worked on channel 04 instead of channel 03
  • walker_44 Nov 02, 2008
    I have the same problem but what are the steps to correct it? where is the 3-4 switch or what do I have to do?
I have the same problem but what are the steps to fix it? Where is the 3-4 switch?
Posted on Nov 02, 2008
  • 579 Answers
Yup, I went through a lot of grief one time only to discover the old 3/4 channel switch!
Posted on Dec 28, 2007
Program toshiba tv remote ct-885
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
    Codes to Check:
    013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
    0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Mar 31, 2012 | Toshiba CT-847 Remote Control
I need the code to program the philips universal remote to a sylvania tv
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 28, 2008 | Philips Magnavox Learning Universal Remote
I have a philips universal remote and an Rca Tv how can I program
code list is also listed
Toshiba vcr W522CG
start over set the tv on 3 and then the vcr . then plug in the vcr and start over
Nov 02, 2008 | Televison & Video
I lost my remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Codes
Hope this helps :)
Jun 04, 2008 | Philips Universal PH301S Remote Control
Philips remote codes
Hope this helps :)
May 25, 2008 | Televison & Video
EWV404 PROBLEM WITH "l1" INPUT
go to the menu and select auto find or auto program channels.
good luck
please mark the post with a fixya!
Feb 06, 2008 | Emerson EWV401 S-VHS VCR
Not enough channels
The history of broadcasting is one of adding more and more channels. The older the VCR, the less cable channels it will get.
Jan 01, 2008 | Toshiba W522 VHS VCR
Toshiba W522 VHS VCR Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
