Question about SoftMath Algebrator - Algebra Homework Solver (689076614429)
An airplane is flying at a height of 2 miles above the ground. The distance along the ground from the airplane to the airport is 5 miles. What is the angle of depression from the airplane to the airport?
  • 416 Answers
a2+b2=c2
a being your height, b is your distance from the airport and c is the distance from the airport to the plane........ so the answer is 5.385164807134504 miles
Pls Rate this post
Posted on Oct 08, 2009
Is it common that small local airports don't have radars?
It is very common for small airports not to have a control tower, radar, or communications equipment. There are very well developed procedures for "uncontrolled airports". There is a standard traffic pattern that aircraft fly at almost all airports (consisting of a downwind, base, final, and upwind leg) and there are specific radio calls that are supposed to be made at certain points in the pattern. Most airports have a fixed base operator to supply fuel and services. They often monitor the common traffic frequency and supply some info to pilots about wind direction and runway in use. There's also a specific way to enter the pattern - usually at a 45 degree of the downwind leg, Yes it's possible for aircraft to collide and it happens several times a year - usually when a low wing airplane is above a high wing airplane in the pattern. Neither can see the other so occasionally that can happen.
Jan 04, 2017 | Aircrafts
How is a pilot supposed to find out their distance in miles from an airport they're landing at?
Using the old (pre GPS) method you would use the sectional and plotter (aviation ruler) and measure the distance. Using a GPS you can usually turn on distance rings on the screen or if you have the airport selected as destination you can read it right off the screen. If it's your home base you should learn the landmarks and their distances from the airport. In the Miami area, there are so many airports and landmarks, if you're flying there, during your preflight preps you should measure out distances to some landmarks that you plan to pass over and mark them on the chart or flight log.
A plane is 48 miles west and 49 miles north of an airport. The pilot wants to fly directly to the airport. What bearing should the pilot take? Answer should be given in degrees and minutes.
Draw the airport. (X marks the spot) Draw the distances from the airport (to scale) to indicate the position of the Plane. Use a protractor to work out the correct angle.
To Calculate:
a=48 b=49 Angle= Tan-1(a/b)
Sep 25, 2013 | Cars & Trucks
I need a repair shop in my area burien wa thanks
1 Bostitch Factory Service
(206) 763-2010
2100 Airport Way S.
Seattle, WA 98134
Distance: 8.04 miles away 2 "Tap Tool Repair, Inc."
(253) 441-2177
10313 LAKEVIEW AVE SW
Lakewood, WA 98499
Distance: 18.00 miles away
Jul 16, 2011 | Stanley Bostitch Nail Gun
Antenna mounting
according to FCC rules RULE 8 - Antenna Height
{A} "Antenna" means the radiating system (for transmitting, receiving or both) and the structure holding it up (tower, pole or mast). It also means everything else attached to the radiating system and the structure.
{B} If your antenna is mounted on a hand-held portable unit, none of the following limitations apply;
{C} If your antenna is installed at a fixed location (whether receiving, transmitting or both) it must comply with EITHER one of the following:
[1] The highest point must not be more than 20 feet (6.10 meters) higher than the highest point of the building or tree on which it is mounted;
or
[2] The highest point must not be more than 60 feet (18.3 meters) above the ground.
{D} If your CB station is located near an airport, and if your antenna structure is more than 20 feet (6.10 meters) high, you may have to obey additional restrictions. The highest point of your antenna must not exceed 39.37 inches (1 meter) above the airport elevation for every 109.36 yards (100 meters, 1 hectometer) of distance from the nearest point of the nearest airport runway. Differences in ground elevation between your antenna and the airport runway may complicate this formula. If your CB station is near an airport, you may contact the nearest FCC field office for a worksheet to help you figure the maximum allowable height for your antenna.
Jul 20, 2009 | Cobra MRF55 2-Way Radio
Distance problem?
75 Miles and 105 degrees northeast?
Feb 04, 2009 | Super Tutor Trigonometry (ESDTRIG) for PC
Tranmitting distance
Generally speaking a 2-way radio will talk as far as it can see. Height and placement of antenna determines range. So if you were talking from a Mountain to a valley you could talk a great distance. However, in the real world there are obstacles, such as trees, houses, varied terrain. You generally would expect a radio to talk line-of-sight up to two miles. Or 1/4 to 1/2 mile if talking from inside a building to outside. The quote of 5 miles in literature is referencing ideal conditions. (Much like when the new car you are looking at quotes the MPG.)
Jul 29, 2008 | Motorola Talkabout T5720 (7 Channels)...
Computers & Internet Logo
415 people viewed this question
Top SoftMath Computers & Internet Experts
k24674
ali_zulfikar
ali_zulfikar
Are you a SoftMath Computer and Internet Expert? Answer questions, earn points and help others
