Sony Vaio VGN-FZ320E is inundated with viruses, only operates in safe mode, will not accept new virus protection, and I have no Vista recovery disc. How can I download one, or will I have to wipe it completely?
Comments:
Oct 08, 2009
- Already tried system restore, there were no resyore points
Try to inquire on sony support. If you can have the recovery cd, usually they will charge for shipping. Have it and your hand its better you have a good fall back to restore your lap on factory settings.
But for your virus infection. You have at least a chance to purge that out of your system since you can boot on safe mode.
Use combofix on safe mode but this could also do some corruption on your system this is for the last resort if ever.
Try to look for antivirus that can run on safe mode on the list, and do some research how it works best.And also try to backup your important files and installation files first before running the antiviruses. And also run antivirus one at a time. Then try to record what virus hits you.
This maybe an overkill. The reason is you don't know what virus infects you then try this antivirus who can distinguish it and run on safemode. The reason I sharing this is it will just infect you easily again even you restore it to factory installation. " Prevention is better than cure".
If ever you disinfect the virus using this, then pick one antivirus that disinfect this infection and uninstall the other. I also recommend Malwarebytes antimalware on the system together with one antivirus.
Goodluck
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
Thank you! I was considering something this, but as you said, only as a laast resort
" - donovanm
I assume that you have already tried a "system restore"... while in the safe mode.
If you can get to a time before the really bad virus hit, you may be able to install a decent virus protection program
If you have another pc available go to www.cnet.com in the search area type malwarebytes the first on the list download and install to your computer.Since you can only use it in safemode install and run it there,do a full system scan,allow it to finish.Once it is finished remove the quaranted items highlight and delete.Reboot this should remove the the infected items.Now you will need to do this once you get back in windows.it will do a update and remove what it finds.Remember always to do a full system scan.
good luck
Was this helpful?
Yes
No
Popular Solutions for Sony VAIO VGN-FZ320E/B 15.4"
Sony VAIO VGN-FZ320E/B 15.4" Notebook PC ( Intel Core 2 Duo...
on my toshoba pc 17'' sreen I have black spot on the top corner and the bottom of my screen , is my...
(More)
on my toshoba pc 17'' sreen I have black spot on the top corner and the bottom of my screen , is my screen diying oley one year old
The machine wont go further than the swirling circle after logging in. I was told by the tech...
(More)
The machine wont go further than the swirling circle after logging in. I was told by the tech support I would need tomreset to factory settings but then it worked. I dont have disks so will need to transfer to a USB
how do i use my delstar netbook i got this for my daughter and we are use to regular computer and...
(More)
HOW DO I USE MY DELSTAR NETBOOK I GOT THIS FOR MY DAUGHTER AND WE ARE USE TO REGULAR COMPUTER AND THIS IS NOT COMING TO US HOW TO USE IT
