Question about Frigidaire Refrigerators
FRS6R5ESBL WILL NOT DISPENSE ICE
WHEN YOU PUSH IN THE DOOR TRIGGER, IT JUST POPS BACK OUT WITH JUST A LITTLE HESITATION.- NO ICE COMING OUT.
SOURCE: ice maker
Continuous ice production, too much ice in the bucket, ice cubes overflowing the bucket, ice cubes falling behind the bucket or ice lifting the chiller shelf can now be resolved by installing a redesigned feeler arm. The new arm is designed with a slight curve to cycle the icemaker “OFF“ before the cubes overflow the ice bucket. Order part number WR49X10103.
Posted on Jan 23, 2008
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
SOURCE: Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
Posted on Sep 23, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
MNfisherman
  • 11896 Answers
SOURCE: The ice maker works, but does not dispense
The bar, hinges or sensor may be broke or shot..
Posted on Jul 08, 2009
Frigdaire model GLHS68EGW2 Ice dispenser does not work on side door. I pulled out the ice tray and held in the switch on the door and pushed on the ice dispenser on the door and no movement on the ice...
The paddle serves as an off and on control for your dispenser, auger and trap door that retains cold air in freeze when finished getting ice it also closes. If you notice something different I would want to rule that out first. Click Here=> GLHS68EGW2 Water Dispenser Parts Breakdown for a larger view, part 24 in photo. You May find the partts here also=> 241685701 or here=> 241685701
for additional assistance I will be here to help you, Thanks Sea Breeze
Aug 19, 2010 | Refrigerators
The outside door water does not work
Can I assume the ice and water are activated by two different switches? The ice switch activates the motor that dispenses ice. The water switch activates a solenoid that opens to dispense water. If you can, find the solenoid and make sure it's not stuck closed (tapping it with a screwdriver handles usually help persuade it a bit). I would tap the solenoid while pushing the water button. Listen for the solenoid to activate. If you can't activate the solenoid, find the switch and depress it with a small screwdriver. Usually, these switches are just simple little microswitches that need a little cleaning and coaxing
Feb 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have model# FRS26R4AW5. The ice dispenser wil
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Jan 09, 2010 | Electrolux Refrigerators
In door ice dispenser runs without stopping.
The door switch for ice dispenser is stuck on and will need to be replaced.
Oct 02, 2009 | GE Monogram ZDI15C Automatic Icemaker
The ice maker works fine but we can no longer dispense ice from the door. No sound, nothing. Water dispenser works fine though.
There is a micro switch behind the panel above the dispenser lever. It's the switch that the leaver presses on when you push a glass into it to fill with water. Pop the panel off and you will see the little black switch I'm refering to.
Aug 15, 2009 | Whirlpool GD5SHAX Side by Side...
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
Ice maker dispenses ice without anyone pushing button.
Possible fault with the electrical connector at the bottom of the door as these can corrode or the microswitch behind the paddle has got jammed , try pulling the paddle forward a little . You should hear the switch click when you push the paddle back .
Mar 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice on door not dispensing
you can look closely under the front facade of the dispensor itelf, youll seee 2 small slits approx 2 inches in from each side, insert a flat blade screw driver into the slot and it should "pop" off then lift it off. when putting back on hook the top and push down as close as possible, sometimes I have to hit them with the palm of hand in order to get to "snap" back into place.pushing down on the top of the facade will also ease in the removal
Apr 08, 2008 | Amana ACD2232HR Side by Side Refrigerator
Whirlpool In-Door-IceĀ® Ice Dispensing System
the dispenser front "pops" off by inserting a screwdriver under he dispenser front, look closely youll see 2 little slits where ot insert and twist from. as your inserting and twisting would be helpful to be pushing down on the top of the facade.(just plastic tabs holding on care full not to break. its pretty apparent after that. when re-installing Hang over the top and kinda give it a good smack down with the heel of your hand... but honestly before all that look at the wires under the door hinge make sure there are no cut wires. ( a natural pinchpoint created by the hinge mechanism)
Mar 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
