WASHER FILL, NO PROBLEMS AGITATING, WHEN TIME
WASHER FILLS, NO PROBLEMS AGITATING, WHEN TIME COMES TO SPIN WATER OUT, NOTHING HAPPENS NO HUMMING, NO SPIN CYCLE WORKS ON THE DIAL HELP PLZ
  • milten1
    milten1 May 11, 2010
    it would be a great help to know the model number or at least manufacture and style front loader vs top loader
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is an illustrated description of how to remove the cabinet on Kenmore / Whirlpool top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Since it won't drain, the problem points to the lid switch. You already have the cabinet off so replacing the switch isn't too difficult.
The Sears site has the Sears (and probably Whirlpool) part number.
Posted on Oct 08, 2009
Wpre6100g1wt
there are two possible reasons
1 belt has come off the drum and motor
2 the brushes in the motor have worn down so far that it wont turn.
did it happen all of a sudden, or over did it get worse over a period of time?
May 18, 2014 | LG Washing Machines
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My Kenmore washer won't spin, agitator is locked up, motor hums..
agitator won't turn, it fills up water and hums
Jun 13, 2009 | Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Doesnot spin or agitate.
if you have the front panel off and you can see the motor is spinning the belt is turning then your transmission has failed.waring keep hands clear of all moving parts! transmission pn wh38x10002 for around $185 if mtr is not moving pn wh49x10040 for about $240 depending on what you need and how old your washer is it might be time for a new one
Dec 13, 2008 | Washing Machines
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Water fills but does not agitate or spin
THIS UNIT HAS A DOOR SAFETY SWITCH WICH ALLOWS WATER TO COME IN BUT NOTHING ELSE TO HAPPEN IF THE DOOR IS OPEN I WOULD START BY CHECKING THIS SWITCH.
Nov 29, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
195 people viewed this question
Top Washing Machines Experts
