Question about Garmin iQue 3600 GPS Receiver
Garmin ique3600 stuck in the calibration screen
Even though I tap right on that little dot. It goes over and over. Can't pass calibration.
Any solutions, advices?
Thank you in advance
    Champion:
  • 303 Answers
Give the screen a thorough cleaning with a soap and water cloth (NOT SOAKING) and allow to completely air dry. Then try recalibrating.
Posted on Nov 03, 2009
Stuck in preview mode
If the back button does not work, power off the Approach.
Connect the Approach to your computer and try running the Garmin WebUpdater to load or reload the latest version of software. This will resolve most issues.
Power it back on and try doing a screen calibration by pressing the wrench in the bottom right corner and arrow down and press Calibrate Screen. Press on the dots using a stylus or the round part on the back of a plastic pen.
You may also want to contact Garmin Support for assistance. 1-800-800-1020
Dec 05, 2011 | Garmin Approach G5 Handheld GPS Receiver
Garmin 1100lm locked in press dot game?
Your unit is in calibration mode. There should be a black dot to press on the calibration screen. Keep pressing the dot as it moves around the screen, you may need to press very firmly and use a stylus until it says calibration complete.
This usually occurs when a unit is dropped or left in extreme temperatures or jammed it a glove box or console with things jammed against the screen. It could also occur if you are touching the screen as you start.
Thanks for using FixYa
Aug 03, 2011 | Garmin nuvi 1300 Car GPS Receiver
When i turn my nuvi on, the screen goes blank and says "press dot"
Keep pressing the dot, its in calibration mode....
if you need to re-calibrate it this is how...
Turn unit off then back on
Slide Power Key to the right ( lock )
Hold your finger on the screen for 30 seconds until the calibration screen appears
Follow on screen instructions
( this may be where you see more dots)
Oct 30, 2010 | Garmin nuvi 255W GPS Receiver
White "press dot" screen
The actual answer is to press the dots, but use a dull plastic tool that fits "within" the dot. Otherwise the width of your finger is too imprecise to calibrate the dots and screen.
Hope you, and others, get this and try it. It works. I just discovered it and did it, successfully after only about 10 presses.
Jul 21, 2010 | Garmin Nuvi 660 GPS Receiver
My garmin 760 screen reads "press dot".
Hiya!
All you need to do is use a ds pen (or something that is plastic and will fit within the black dot) - our fingers are to big for the calibration. Ive just fixed mine. It should correct its self within 10 dots and away you go again :)
Jul 12, 2009 | Garmin nuvi 750 GPS Receiver
Garmin Nuvi 350 Calibration Issue
Turn the unit off. Press and hold down the power button and keep holding it. You will see the screen light up and it will say "pre-boot mode". Keep holding down the power key. It will then say "booting". Keep holding the power button down. You'll then come to the calibation screen. Select the dots and you'll be back in business.
- Jim
Oct 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin 360
Have you tried performing a soft reset by pressing the reset button on the back of the unit, then turning it on again?
How about a hard reset?
With the unit powered off, hold your finger on the upper right- hand corner of the touch screen and tap the power key. Continue to hold your finger on the screen until you get a warning message. Tap "OK" to reboot the GPS.
Please let me know if I can be of further assistance to you.
- Jim
Feb 15, 2008 | Garmin nuvi 350 GPS Receiver
Garmin c330
Try to calibrate the touch screen. Push and hold the power button on until you see a white dot on the screen. This is the calibration mode. Touch the dot and another dot will apppear, now touch this dot again, keep doing this until the unit reboot.
If you touch the 1st dot and nothing happens then the digitizer on the LCD is dead. If the unit is still under warranty, get a RMA and return it to Garmin.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 200 wont calibrate
I think I just solved this!
(I had the same problem.)
Hooray for google!
I found the answer here: http://www.gpsreview.net/forums/viewtopic.php?t=4999
"72 Troubleshooting - Screen:
If the touch screen is not responding to your taps properly, calibrate the screen.
Turn the Nuvi off. Then, slide and hold the Power button to the left for about 30 seconds."
After you slide, and hold, the power switch to the left (ON position) for 20-30 seconds, the next screen that comes up should be the calibration screen, telling you to press the dots on the crosshairs.
I recommend using your finger to press the dots, just as you would in your vehicle. I thought I could be more precise using a stylus when I first got the device, but apparently that is what caused the problem in the first place.
Live & Learn!
FWIW -- I have the Garmin Nuvi 200 (not 200W).
I don't know why this problem is listed under 76Cx.
Oct 09, 2007 | Garmin GPSMAP 76Cx GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
110 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
