Question about Marantz SR-880 Mark II Receiver
After 10 years of excellent use the unit just failed to power up. I rested it for several weeks and when I tilted it backwards it worked again for two days. No fuses seem to be blown.
  • Marantz Master
  • 5,391 Answers
Is there are bad solder joint somewhere? Does it get moved around a lot or get knocked, that might cause a break?
Posted on Oct 08, 2009
E500i-B1 won't come on.
Suspect a failing power supply
Jan 13, 2017 | Televison & Video
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
Our rinnai R94LS will shut off after running several minuets and shows error code#10. I'll turn it off for several minutes and turn back on, run system for several minuets and it will shut off again and...
Tankless computer is not working.
Error 10 is blocked flue or inadequate air supply. Or failed PC motherboard, or failed sensor etc.
Get more fresh air to unit. Check if bird built nest on flue pipe. If flue exits side of house, look for obstructions nearby that can slow the exit of poisonous vent byproduct into the air you breathe. For example trash cans and boxes or parked car etc.
http://waterheatertimer.org/pdf/Rinnai-installation-and-error-codes.pdf
Call service technician who is qualified to work on tankless computer. This will be a well-seasoned veteran of computer technology and plumbing expertise ... a plumber who knows how to fix computers lol.
This person will catch unit up on required yearly maintenance, and check specialized operation conditions needed for tankless computers to function properly.
If tankless computer is older than 5 years, then compare it to your 5-year old laptop, and assume same level of glitches and problems.
Solve any tankless problem yourself, today, for $385 by installing tank type heater from local box store:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 29, 2013 | Rinnai Water Heaters
My Maytag model number MEY18F7E will turn on for about 10 seconds then quit and trip the breaker. It just started doing this about a week ago. Has been working fine since I purchased the home several years...
Sounds like you have a bad compressor, something is either shorted out, or drawing too much power causing your breaker to trip.
Is this a window unit, or a ductless unit?
Aug 23, 2013 | Maytag Heating & Cooling
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
Water leakage, just started using since June.older 10 yrs +_ Marty Margolis
Hi!!
Make sure unit is tilted backwards about an inch so condensed water can drain in the back. Make sure drain hole is not plugged, if so, use a piece of wire to unplugged.
AC units have to be serviced at the beginning of summer every year or at least every other year . It will be cheaper to take unit to service shop than to have a HVAC Tech come to your house.
Good Luck!!
Aug 14, 2010 | Kenmore 75085 Air Conditioner
The machine stopped with 33 minutes remaining on 96. There is a "pumping" sound but no water comes in. The dial says it is on rinse but it does not rinse. Bosch Dishwasher EN: SHU4326UC/U12 FD8007. 260415...
If you have water filling up in the sump, you will get that scenario. If water is out of the tub, pull unit out and tilt backwards about 45 degrees. If water comes out from the base(sump), then you know you have a leak and need to have it attended to. Note, if water does come out when tilting the machine backwards, you will find it will work again until base is full again.(Switch off before tilting the machine backwards just for safety.
Jul 21, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
It just stop clooing i have cleand and vacumed every thing under the unit its starded to work for a week and now it just stoped again thanks jerry
the condenser located underneath is choked already with accumuated dirts.you could not removed all those accumulated dirts under the units sir,to do it , unplug your unit tilt it backward, in a safe angle,or remove the back cover of the unit, you can have a full view of the condensing tube,sometimes it gets clogged with your pets hair or accumulated household dirts, clean it and be a little bit carefull to avoid damaging any part.
Mar 18, 2010 | Refrigerators
Haier HDP18PA
On another site, someone posted this: "I called (website), where it was purchased from, and they gave me the number for the manufacturer. Some standard troubleshooting did the trick and my dishwasher is working perfectly again. The troubleshooting involved tilting the dishwasher backwards at a 45-degree angle and letting any excess water drain out. They said ocassionally the water intake will be blocked and this process helps move anything that may have gotten in the way"
I was having the beeping problem too, and decided to give it a try, tipped it for a few, and found it to work!!! Hope this maybe helps!
Jun 09, 2007 | Haier HDP18PA Stainless Steel...
162 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
