Question about MSI P4MAM2-V Motherboard
DEAD BOARD HOW DO YOU TEST THE BOARD TO SEE IF IT IS OPERATIONAL?
    Scholar:
  • 73 Answers
Easiest way to test is to observe whether there is a POST beep when you power it up. No beep usually means a dead board. Another way is to obtain a POST diagnostic card, which will tell you the exact problem.
If you have not already done so, I suggest you remove everything from your motherboard, excluding the CPU. The most important thing is to leave the RAM out, as all motherboards (excluding very old ones) will emit a beep if there is no RAM present. Again, if there is no beep, then you probably have a dead board.
Hope that's somewhat helpful.
Posted on Dec 25, 2007
How do I fix...? SC817 error in Ricoh MPC3002?
I have found that a sudden power outage or failure can cause the HDD to go corrupt giving you a false code like SC817.
You can either try formatting the HDD in the machine or if that fails you can remove it and format it in a PC or HDD dock.
If this doesn't work replace the HDD.
If you still not convinced it is the HDD, simply see if the machine is operational after you have disconnected the HDD. That's a dead give away.
Jun 18, 2016 | Ricoh Office Equipment & Supplies
DID AUTO TEST MODE RAN THRU CLYCLE SOLID GREEN DONE LIGHT IS ON NO OTHER LIGHT'S CAME ON
lift the lid. done light indicates that test cycle is complete. If you are getting done light only, all the time, control board is not recognizing that lid was lifted, allowing it to go back to normal operational mode. check lid switch and control board.
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. top load...
I DID NOT USE TREADMILL FOR ONE YEAR, IT WAS GETTING OFF WHEN I STEP ON IT, RECENTLY WHEN I START IT AND PRESSED GO BUTTON, THERE WAS SMALL BURST IN THE LOWER BODY WITH A SPARK, AGAIN WHEN I SWITCHED ON...
Dear Sir:The dusct, some animal, can be break some wires. And for that reason there are spark.See the 1) fuse and replace 2) C.breaker reset 3) Test any wires loose or corroded 4) Any wires breaker repair 5) Some dead animal inside. 6) Test the power cord 7) See some component burn inside from the main motor board 8)tEST the main motor for burn or some wires breaker or loose, or anything.9) Test the speed sensor, clean, and tight the connector wires very wellYou need LUBE the machine in according with the instruction manual maintenance. Maybe you need the help from some service tech.
sincerely. God bless you
May 03, 2012 | Proform XP 580 Trainer Treadmill
Display flickers and dies what is wrong? it seems either the inverter has failed or the light is failing. how do i know which needs replacing.
The CCFL tubes are practically immortal - the laptop itself will be dead long before them. If sometimes you get lightr that means that the inverter board is still operational and what you have is a bad wiring connection.
You will have to dismantle the lid and check the wiring and its connections.
Nov 13, 2010 | Dell Inspiron 1300 Notebook
When booting the ds20 compaq server from system disk it brings an error saying scsi drive at channel 1 dead, target 0 dead and goes on to say the same for all the other disks
If you are sure the disks are ok (they could have been fried by a bad power source) then the SCSI chip is probably dead.Simple test: remove all hard disks and boot from the recovery disk. If you are lucky it will report all HDD channels operational and without disks. Insert another certainly good disk and boot again and see what happens.
If you're unlucky it will report the same thing - dead channels. In that case you will need at least a new SCSI card (they don't just die by themselves).
Mar 27, 2010 | Computers & Internet
My Carrier Infinity Hybrid Furnace/HeatPump is suddenly not responding. It's been working for a few years, but today it's acting dead. All the breakers are on. At the furnace (58MVB series 100) I hear a...
The buzzing sound your hearing is a transformer that is producing 24v ac current to the main control Board, this is what controls the unit. you can check for 24v to the main board by removing the front panel access door and finding the safty shut off switch that the door touches, and depress it or tape it so you can test for voltage.. if you have 24v ac from the transformer next test at the board, if you have voltage there you may have board issues??? check the fuse on the board, make shure all connections are good... if you do not have 24v to the board your transformer is bad, have a hvac technician service this, don't attenmpt to do this yourself if you don't have experince, you could destroy your cont. board.....
hope this helps
Jan 17, 2010 | Heating & Cooling
Need to test Hoveround mpv4, batteries are dead
No you will have to have proper working batteries.
Mar 19, 2009 | Electric Mobility Power Electric Scooter...
Dlp bulb
Its Bad if it does not Light! Call Encompass Parts or look up their website for listings of Parts to your TV.
1-800-638-3328 also I have found some good deals on Lamps on E-Bay got one for mine for 85.00 and got my Ballast Board for 65.00
Mar 02, 2009 | Loewe Articos 55 55" Rear Projection...
No power
with my satellite, i had to charge it before it was operational.
if its charged, look on the front panel, is the battery light red, or blue.
red means its dead.
blue means its fully charged
Jul 01, 2008 | Toshiba Satellite A135-S4527 Notebook
Home phone
unplug phone line from printer, see if phone is operational, try another phone in the wall plug, if not working, go to outside box and plug phone into the test item, if not working call phone company as it wuold appear line dead/cancelled.
Jun 21, 2008 | Office Equipment & Supplies
MSI P4MAM2-V Motherboard Logo
114 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
