Question about Frigidaire GLTF2940ES Front Load Washer
Washer spins while washing, it will also drain with no issue but will not do the final spin? help!
    Problem Solver:
  • 4 Answers
Any error codes? Try putting it in diagnostic mode. You can test different cycles and retrieve error codes. Instructions should be taped in an envelope to the inside of machine. You may have to remove the bottom front cover to find them.
Most likely cause - Faulty door switch.
Posted on Oct 13, 2009
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
Won't do final spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer does not drain and spin
If this a whirlpool brand washer, check your lid switch. When they start going bad, they can be intermitent. While the washer is in the spin cycle, if there is no motor noise, push down on the lid above the lid switch and see if it starts.
This is the most common issue.
I hope this helps
Vic
Jun 20, 2009 | Washing Machines
Help Guru Please
Ill try,
first off its normal for water to spray in during the final spin( its a spray rinse), as far as the water coming back into your machine after the final spin stops, you have an issue with oyour drain, i would assume that the drain hose is NOT going into a stand pipe"open drain", but instead clamped to another hose leading outside or to a drywell, in which case youll need to install a "one way check valve". whats happening is after the final spin is done al;l the waterin the drain line is reurning back formn the drain hose.Proper insstallation will cure this.
lastly its hard to describe"slower than usual spin" it will progressivly spin faster as moire water is removed form the machine, i wqould rectify the drain issue before i concern my self with this( and make sure you not selecting a :gentle spin" option of coarse... hope this is helpful to you!
Jan 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Final spin cycle issues
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
HOPE THIS MAY HELP YOU;
Regards,
VOTIT
Sep 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer will not Spin during SPIN CYCLES
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
122 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
