Question about Sony Ericsson w580i Cellular Phone
Power on but display and key pad led ont on] - Sony Ericsson w580i Cellular Phone
  • 64 Answers
It sounds as if the flex in the slider mechanism is damaged. you will have to take it to a repair centre to get it repaired, depending on when you bought it it should be free. the phone has a 2 year warranty.
hope this helps.
g
Posted on Oct 26, 2009
Display backlight solution
Possible failure in the panel board as the LED's tracks could have been damaged. It is ideal to open the phone and get access to the front panel. Check the LED's by using a multimeter , it will light up in the low range. if so the back light must work unless a track has opened up ont his high density board. sometimes the plated- through holes would loose connection. if so you need help to concur and estimate.
Apr 11, 2011 | Nokia 6303 Cell Phone
I have a Kitchen Aid KGRC608lsso, the key pad
I have the same problem with my KGRT607H. I took off the control panel, and wiggled some wires, then it worked (the LED display). Seems to be a loose connection, with one of the wires going into the connector. I myself haven't replace the connector yet, I just take the control panel apart, and wiggle the wires. Pain in the ****, so one day I will try to replace it either that or try to secure it better. My next step is to find out which wire leading into the connector. (figuring its either a bad wire). On my control panel, its the connector that has all the 'white' wires going into it, not the coloured ones.
May 20, 2010 | KitchenAid KGRC608LSS Gas Kitchen Range
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
SPECIAL TESTS
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
keys:
Press Keys Special Test/ Function
wrinkle
release Diagnostic Codes
dryer
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
Number
very dry(< ) View current cycle
temperature (Co)
start/pause
Start or pause cycle running
but remain in Diagnostic
mode
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
dry
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
www.appliancehelponline.com
Mar 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Codes F-21 And F-33 are showing up
this error occurs if the touch-pad/led assembly is not able to transmit/receive data to/from the central control unit (CCU) 1 check the touch -pad/led assembly by selecting different cycles and changing the modifiers and options available to confrim the touch-pad/led is responding. 2 unplug washer or disconnect power. 3 check wire harness connections to the touch-pad/led assembly and central control unit (CCU) now to the f-33 code system leak if after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR if the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. press PAUSE/CANCEL twice to clear the display. possible causes/procedure 1 check for crack or holes in the washer tub and pressure switch hose. 2 replace components if necessary good luck
Feb 16, 2010 | Maytag EPICz 3.7 cu. ft. Washer
Maytag neptune washer keeps beeping
The Service Manual for reference. Sears Parts Direct for reference.
I have tried to work with a few folks on this issue never received feed back to resolution see this post. I feel the issue is caused by one of three possible issues.
A stuck key issue/defective Spin Cycle key making constant contact forcing the Key/LED to cycle thru the Spin Cycle settings. Under normal conditions if you press and hold the Spin Select key it will cycle thru the settings, yours has a mind of its own (defective issue).
A false signal from the Control Board for the Spin Cycle.
A corrosion path issue at the Membrane Pad ribbon cable socket connection between pins 5 and 4. See page 20 of the SM button functionality “Spin” key.
Try to verify that the spin cycle membrane key is not stuck/defective signaling the Control Board to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test to get a start point. See the Service Manual page 15, I have modified the process to make it a bit more understandable at least for me. Make sure the two digit display is not On or Lite.
Press the off button first so there is nothing displayed in the Two Digit display of your FAV6800AW.
Now Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys for three seconds or until the control beeps. While in Service Mode, pressing the Presoak key will start a membrane switch check that verifies switch operation.
All the LEDs (except Presoak ) can be toggled or slewed by pressing the key associated with the LED or set of LEDs. Do not press the Presoak again during this test.
Press each key once and only once including the Signal Key the on side and the off side, also the UP and Down Arrow key of the LED display. All keys (including the OFF button) must be pressed within 5 minutes for this test to pass. “PA” will be displayed for five (5) seconds once all keys have been pressed and the test is completed (more like PA will be displayed for only a few seconds on my FAV6800AW). Following 10 seconds of inactivity at any point, this test will exit without any display. Let us know the results.
See my additional comment this board has message limit issues.
Sep 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
LifeBook T4210, some letters ont the keyboard doesn't work
hello
Some of the letters stop working due to dust that stuck between the pad and board..Or due to degradation.
So you can try cleaning the keyboard with vacuum cleaner and clean properly between the keys.
If the keys still don't work you can replace the keyboard as it is replaceable.
Thank you
Jul 13, 2009 | Fujitsu Siemens LifeBook T4210 Notebook
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Maytag Neptune Tl Spin settings
I would try verify that the spin cycle membrane key is not stuck/defective signaling the controller to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test to get a start point.
Do you have the troubleshooting guide stored in the control panel? It was shipped with the machine, pull 120VAC washer power plug, remove the top three torx screws at he top back of the control panel and remove the trouble shooting guide. Rassemble and power up your machine. Follow the instructions for Membrane Pad Test. You will enter Service Mode to verify that the key pad function LED can be toggled, just press each key once except the Presoak key as described below. If you don’t have the Troubleshooting guide that came with your FAV6800A I have pasted in the test from the SM;
Membrane Pad Test
operation. All the LEDs (except Presoak ) can be toggled
set of LEDs. Each time either set delay arrow is pressed
the digits toggle between a blank and 8. All keys
test is completed. Following 10 seconds of inactivity at
Let us know your results.
Dec 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Sony Ericsson w580i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
