Question about U-Line Icemaker
My U-Line CO2075FS ice maker seems to over fill and drip water into the ice cube storage drawer. How do I adjust the water flow or fill level limit?
  • 286 Answers
If your water is overfilling then you probably need a faceplate for your icemaker. If you remove the cover on your icemaker(pry on the corners and pull @ same time) You will see a screw with a spring on it. That adjust the water flow. If you tighten you decrease the water. Make sure the gears are not corrioded. If it is. Replace the plate with the gears on it.
Posted on Oct 08, 2009
Raritan icer-ette only filling 5 of 8 slots in ice mold
They marine ice makers are fussy. The ice maker needs to be level or water will drip down into the ice bin. The amount of water entering the tray is controlled by time. The other factor is pressure. The marine water system has a relatively low water pressure as compared from marina water feed.
I would confirm the number of cubes produced from the unit when connected directly to the city water pressure. If at the highest pressure it is below expectations I would follow the video. How Do Adjust an Icemaker Home Appliances
There is a screen filter before the solenoid line that can fill with debris. So you may need to check it if you can not make a satisfactory adjustment.
If you are like me and always work form the internal water tank avoiding a burst water line and "sink the ship" then adjust it for the lower pressure.
Happy Sailing
Dec 09, 2015 | Raritan Icer-ette Ice Cube Maker
Why is my Uline ice maker filling with water not ice ?
At first I wanted to say it has to fill with water to make ice but I know you mean the ice bin is filling with water. You either have an issue with the water control valve leaking or your timer isn't working properly. Listen for the water to flow and when it seems to shut off look at the tray fill spout and see if it actually stopped dripping. If it continues to drip (not flow normally) then the valve is leaking. If it isn't dripping but the water in the ice tray over flowed, then the issue is either with the timer or the adjustment is incorrect.
Jun 04, 2014 | U-Line ULN Marine Series 12-lb Crescent...
Ice maker leaks water
The GE Icemaker has a center bottom plunger that drives the ice cube discharge tray up and down. If that center plunger oring has failed the ice maker will leak in a drip drip drip fashion. If it only leaks once every cube cycle then it is overflowing when filling. This can be corrected 2 ways. One is to turn of the water supply line and disconnet the water line on the back of the unit. Place the hose into a large bowl of some kiind and then have someone open the valve until the flow is full and then reduce that flow about 50 percent. Remember how many turns it took to get that flow and shut off the water supply line. Then reconnect the line and turn on the water the number of turns you counted when shutting off the water. The PROPER way of setting the water flow timing is to frome the front cover of the ice maker and turn the adjustment screw in the DECREASE direction. My suspicions are that the plunger o-ring is leaking. It costs nearly as much to have the service call to replace the o-ring as it does to replace the ice maker. Your choice but I would replace the icemaker if the plunger is leaking. (mid-bottom point of ice maker) Just note that once a leak occurs in the plunger area if the plunger has corroded the new o-ring will wear out rapidly.
Jan 03, 2010 | GE Profile Stainless Bottom-Freezer...
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Ice maker seems to be dripping water onto ice in ice container
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
No water flow to the ice maker
Here's a kinda clumsy solution: I had a similar problem--for several years I'd manually pour in just enough water to fill the spaces. Sometimes the ice maker would then start to work again for a couple of weeks. We have hard water, so I assume it's a problem related to minerals building up somewhere.
Anyway, most recently, I had some cubes frozen in the bottom of the drawer so grabbed the drawer and pounded it in and out a couple of times, bumping it onto the back wall a couple of times. Voila, the maker started making cubes. Now every time I get cubes, I first pull out the drawer halfway and then shove it against the back wall. ...seems to work--the drawer is always filled to the brim no matter how much ice I take. It's been a couple of months now so seems to be working...
Mar 21, 2009 | KitchenAid Refrigerators
Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Jun 23, 2008 | U-Line Icemaker
Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
Jun 22, 2008 | U-Line Icemaker
Small ice cubes The ice maker is not supplying enough water. The result is very small ice cubes. The water supply pressure is on max, can there be a way to adjust the water level? The tray is not even...
The ice maker is time filled, it only has a certain time in which to fill. There is no way to adjust the water level. Check the pressure limiting valve which is in the water line before the filter. Have you replaced the filter? Remove the filter and pressure limiting valve and see if the ice maker receives more water. If it does, then replace the filter and check again. If it is still good, the pressure limiting valve is faulty.
Oct 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
U-Line Icemaker Logo
485 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
