Question about Binks Model 7 Conventional Suction Feed Spray Gun, 1.8mm Tip
Delivers the product but has a pulsating spray Binks Model 7
Delivers the product but has a pulsating spray resulting in a surface that is not uniform. I was spraying lacquer( before there was a urethane) and it was working perfectly. I couldn't keep my hands off of it. I thought it was working well if I get it rebuilt it will work even better. Wrong. My first real experience at being brain dead. I had it rebuilt at a local business that specializes in spray gun systems. They told me I should leave it alone. They were right. It hasn't worked well since. Sent it to a binks guy in Philadelphia. No luck there either. Years later and I still use it on occasion. works well on a small area. Bought a rebuild kit but not sure if I have the correct tools to do it or if it will even help. Trash time or what. Thank you.
    Brigadier General:
  • 4,088 Answers
There is actually very little in the gun in the way of parts. The outer front nozzle unscrews, then the inner nozzle (you need a thin open-end wrench). The fluid and air controls unscrew from the back with loose springs. The fluid needle pushes out the back and the air valve unscrews from the front side of the handle (you may need to remove the trigger to get the valve out). The only critical area is outer and inner passages of the two front components. Soak the entire gun and parts in gun cleaner for an hour or two, then blow everything clean with compressed air. Lightly lube the trigger bearing, fluid needle (not the thin part), and air valve assembly. Put a little light grease on the threads of the two controls and their springs. Don't oil anything around the nozzle. Hopefully, you found a wad of paint in the gun body after soaking it. After reassembly, check the air flow first which should not pulsate. If it does, check the air line with a blow gun--does it pulsate? Check the regulator, hose, and air filter if it does. If the air delivery is good but the gun still pulsates while painting, check the paint supply system. Hope this saves the gun--I've had a Binks gun for many years and it was well used before I got it.
Posted on Oct 08, 2009
Fish eyes & overspray
make sure you clean the surface with acetone or a degreaser and tack cloth before you spray
May 27, 2012 | Binks Model 7 Conventional Suction Feed...
I am not sure how to remove the head and body screw from inside a binks model 7 spray gun....it is tight and dont want to break anything
remove bottom adjustment screw this is the fluid adj rod will be a long one, then you should have a special wrench that came with gun , there is a square surface behind the tapered head that seals to the fan cap put wrench on the square part and remove, being careful noy th burr up tapered surface on front of valve, then you can thourly clean out gun, make sure not to loose any seals during process, do not sand or use abrasive material on these parts, use lacquer thinner and brush,you do not want to bend or scrape these in any way shape or form, caues then your gun will not spray right when reassembled. good luck
Aug 06, 2011 | Garden
I bought a spray gun and wanted to know the difference between the two air caps one is numbered 36SD and the other is 67PD I have a binks spray gun.
67PD PE Used for Zinc rich and other abrasive coatings, the 36sd is a general nozzle that is used for most applications, if you need assistance,, heres their number Technical Support Tel. 888-992-4657 Fax. 888-246-5732 or you can check their PDF located here . http://www.southernfluidsystems.com/BICONV.pdf
Apr 22, 2011 | Binks Model 7 Conventional Suction Feed...
I am trying to find a manual for a binks 2001 spray gun i am having trouble figuring out where the o ring number 7 goes
I looked up same gun. I think I googled "binks model 2001 spray gun" and I got a pdf with all info and diagrams. On the available websites, I looked for the one that looked like official Binks site.
The PDF # I got is 77-2316R-14.pdf. It shows that #7 o ring
Nov 05, 2010 | Binks Paint Spray Gun Repair/rebuild Kit...
No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See Binks.com for detailed tip combinations.
Jun 30, 2010 | Binks Model 7 Conventional Suction Feed...
I need a users manual for a binks model 15 spray gun
Here you can find a manual: http://www.tpub.com/content/automotiveaccessories/TM-9-4940-507-14-P/TM-9-4940-507-14-P0006.htm
Michael
info@bsc-teknik.com ' www.bsc-teknik.com
Jun 14, 2010 | Binks SPRAY GUNS & OUTFITS
Spares for binks 630 spray gun
You can find spares for Binks 630 here: http://sprayfinishingstore.com/products/spray_gun/classics-gun/binks-630-gravity-spray-gun/
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Sep 29, 2009 | Binks Air Tools & Compressors
Binks  Model 7 Conventional Suction Feed Spray Gun, 1.8mm Tip Logo
869 people viewed this question
Top Binks Air Tools & Compressors Experts
JOHN LAPIER
Rick Amick
Rick Amick
john h
Are you a Binks Air Tool and Compressor Expert? Answer questions, earn points and help others
