Question about LG Dare VX9700 Cell Phone
Date and Time will not appear on the screen. Go into Setting and Tools, then Display Settings and the phone kicks out to the Verizon Logo and restarts itself.
  • 47 Answers
Try removing the battery for a minute and put it back in. This will reset it
Posted on Oct 21, 2009
I cant change the time on my adamant verizon cell phone
Go to Settings and Tools. Select Phone Settings. Select Network Mode. Select Global.
Then go back to phone settings and the option to set the time and date will appear.
I reset my clock this way and it worked. I hope it works for you.
Nov 09, 2012 | ZTE Adamant - Black verizon Cell Phone...
Setting the date and time
After selecting 1, type in the date mm/dd/yy (it doesn't appear on the screen) then press hold/save. Then type in the time again it won't appear on the screen press hold/save. It will then return to the main screen with the correct time and date. Hope this helps.
Oct 16, 2012 | LG Ericsson LIP-8012D 12 Button IP Phone
How do I got the verizon logo to get off my front screen
Ralph
Contact Verizon to have them look at the phone.
Mark
Motorola Support
Sep 20, 2012 | Motorola Mobility MOTO W755 Cellular Phone
Trying to find where bluetooth info is located on phone it is a casio g zone
hi,
Setting & Tools
My Verizon ~ Tools ~ Bluetooth Menu ~ Sounds Settings ~ Display Settings ~ Phone Settings ~ Call Settings ~ Memory ~ Phone Info
In tools you get Bluetooth info
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | Casio G''zOne Type S Cellular Phone
I have a Moterolla V3,my LCD screen is not displaying correctly, I see white and red, but I can't make out anything else. When the phone initially turns on the screen displays the Verizon perfect...then it...
The flex that connects your screen to the phone board is bad and has worn out. It is commom with flip phones. All you need do is to replace the flex and be very mindful of how you close the flip phone.
Take care.
Nov 16, 2009 | Motorola Mobility RAZR V3
Lost my manual
DatelTime Settings
1) Set the Power Switch 4D to "1M!" while pressing
down the Lock Button (I) located on the switch.
2) Press the MENU Wheel 0 in. The Menu Screen
appears.
3) Rotate the MENU Wheel 0 to select
"~TO SYSTEM MENU" and press it to display SYSTEM MENU. Rotate the MENU Wheel 0 to select "~NEXT" and press it to display the next page.
4) Rotate the MENU Wheel 0 to select "DATE/ TIME" and press it. The DATEITIME Menu appears.
5) To set "YEAR", "MONTH", "DAY" or "TIME" (hour/minute), rotate the MENU Wheel 0 to select the desired item, and press it. When the setting begins blinking, rotate the MENU Wheel o until the correct setting appears and then press it. The setting stops blinking.
6) When none of these settings ("YEAR", "MONTH", "DAY", "TIME") blinks, rotate the MENU Wheel 0 to select "~EXIT", and press it. The Menu Screen reappears with the highlight bar on "~RETURN".
7) Press the MENU Wheel 0 in to close the Menu
Screen.
. To display the date and time in the camcorder's display and on a connected TV, see DATEITIME
DISP. (U pg. 21) in SYSTEM MENU.
. The date/time cannot be stored in memory if the built-in clock battery runs out. Consult an authorized JVC dealer for replacement, or set the date/time as necessary before you start shooting.
Dec 17, 2008 | JVC GR-SXM260U Camcorder
Display time and date
Go to your phone's "Time & date" settings and select "show", u might have your date and time hidden this time. And more thing, set the time and date first, some phones displays time and date automatically after setting...unless the user choosed to hide it...good luck! i hope this solution solved your problem.......
Oct 09, 2008 | Motorola Mobility RAZR V3
UNLOCK CODE FOR LG CHOCOLATE VERIZON PHONE
moz-screenshot-1.jpgTo Unlock KG800/LG Chocolate
1. Insert sim from the network that it is locked to.
2. Turn on phone
3. On home Screen, Slide up phone
4. Type 2945#*#
5. ENG. Mode menu should appear
6. Go Down to Factory Reset Select it, may take a few minutes to reset!!!!!
7. This will reset the phone back to before the Phone was locked to a network
8. The phone will automaticaly Restart(Note The Network Logo At start up will not change)
9. Now insert Any simcard(Not tested with 3 sims)and the phone should turn on normaly
10. The phone is now unlocked and you can customise the setting as you like.
Sep 24, 2008 | Cell Phones
Front screen only displays upside down Verizon logo....
Sounds like you should take it to have it looked at. Theres something up. The verizon thing only appears when the phone is opened so there must be something out of place in it so your phone can't read when it's closed. So I really can't help you there. To set the phone calls to answer automatically go to "menu" then "call settings" under "settings & tools". Now go to "in-call setup", then "answer options" and under there you'll find the choice to change it to open to answer. Hope this helped!
Mar 18, 2008 | Motorola Mobility V325 Cellular Phone
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
LG Dare VX9700  Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
