Question about Yamaha RX-V463 Receiver
Yamaha rx-v496 loses sound when change from dvd/ld to sat/d/tv.If sound works, it loses it intermitently.Indicator arrow seems dimmer than when on dvd/ld.when changing back and forth it may work for awhile then cuts out...
After switching back and forth now seems to work,(possible falty switch?)
Posted on Oct 09, 2009
Someone sat on the remote control for my Yamaha rx v557 and I have no tv picture--do have sound. System is set up to Direct TV. I can change channels and hear everything fine, but can't get a TV picture It...
If it was the remote that changed the function then likely the mode has been changed. You probably need to have it changed back to the input you plugged your DirectTv into, such as video1 or component, or cable/sat. etc, etc...
Dec 14, 2009 | Yamaha RX-V557 Receiver
MY DTS is not working, not sure if connections are done correctly.
You have to use ether optical or coax connection, DVD disk has to have a DTS content (not every disk has DTS)
Dec 02, 2009 | Yamaha RX-V496 Receiver
Voices vs. sounds
If you are passing video thru the monitor out to the TV, this will go much easier. First Press the GUI Menu button on the remote. If connected to TV, on screen menu will appear. Go to Manual Setup then (right arrow on the 4 way with the ok in middle) Speaker Settings then Speaker Select then go to Center Channel arrow right again and make sure it's "On" If it is, then go back to the main speaker settings and toggle to Speaker Level. Then select center channel and arrow right turns volume up. If you still have no audio, post a comment and I can help you troubleshoot further. Hope this helps
Nov 19, 2009 | Yamaha RX-V496 Receiver
Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Yamaha RX-V663 Receiver
Losing digital picture with HD TV
First, hide the remotes so that the TV cannot "see" it. If the problem goes away, it's the remote. Other than that, it sounds as if the receiver is faulty...accordianman
Nov 02, 2008 | Yamaha RX-V861 Receiver
How I connect DVD Player thru Yamaha RX V2090
please check your input source in tv and confirm right selection-check interconnect cables.
Jul 21, 2008 | Yamaha RX-V2090 Receiver
TV on But no Sound
cheak syterio outs puts and dvd players settinsg to pcm output ect reset them up
Feb 03, 2008 | Yamaha RX-V661 Receiver
Digital Audio moved from TV/SAT to DVD/LD
Using the remote control, push the left arrow until display shows Coax1 (or 2, depending on your setup), then push the up arrow to set it to TV/SAT.
Conversely, depending on your setup, you can push the left arrow to display Comp1 (or2) then push the up arrow to set the correct video setting-- DVD/LD I assume.
Apr 09, 2007 | Pioneer VSX-D514 Receiver
Yamaha RX-V463 Receiver Logo
165 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
