Question about Kenmore 57029 Side by Side Refrigerator
Sears Kenmore Elite Refrigerator - Model 106.57713700 When I press the dispenser switch I hear a click and nothing as long as it is depressed. When I release the switch I hear another click a moment after release. No ice will dispense. The light goes on when switch is depressed. Water dispenser works fine. Sears Kenmore Elite Model 106.57713700
  • 15,935 Answers
It appears your selector microswitch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
The ice dispenser is not dispensing ice. When you put a cup under dispenser and push in, nothing happens. Its a Kenmore Elite, model 106.5896*701
here are some places to look, check the dispenser switch is working and also that it is being activated by the mechanizm, check that the auger is turning, if not is the motor getting power but not working? is the selector switch in the correct position and is it making contact...
Aug 22, 2011 | Kenmore Side by Side Refrigerator
We own a Kenmore Side by side refrigerator, model #253.54622406. The water has stopped coming out of the water dispenser in the door. What could cause this?
if the ice is opperating normaly listen for a click or humm from the water valve if nothing it may be the switch first check for power at the valve when switch depressed if present replace the valve if valve has power and you hear it oppening and closing it or the line to the dispenser may be plugged. if no ice either check the water supply to the fridge and the filter in the fridge if there is one.
Mar 08, 2011 | Kenmore Refrigerators
The ice maker works perfectly in my Sears Kenmore Elite Refrigerator, but the ice crusher doe snot work. When i put the glass under or I push the lever, no ice comes out. I have removed all the ice sevral...
Push the lever to dispense ice and listen for a small click sound,(the micro switch). If you hear a click you will have to determine if there is a broken wire to the dispenser motor or if the motor itself is defective, This will not be a visual diagnosis unless you fine a broken wire in the hinge area.
Eric
Nov 19, 2009 | Frigidaire FRS-26DR7D Side by Side...
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
I have a Kenmore model 106 9555710 SxS - no wate through door
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
Jun 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
take out ice bin, make sure you get it lined up when put back together, should click,sometimes they are a little off and you have to keep trying, mine has that defect, it works, but only on its terms, its a pain to do, but that can stop it from working due to a safety thing
Oct 30, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No ice through dispenser
When you operate the ice dispenser lever, you should be able to hear a little click from a micro-switch that then switches the auger motor and the light on and also opens the flap. If you cannot hear this small click, then the micro-switch is faulty. The ice dispenser only works when the freezer door is closed, so you could also inspect the door light/fan switch for proper operation.
Oct 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 57029 Side by Side Refrigerator Logo
279 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
